Closed Thread
Old 07-29-2012, 11:57 AM   #1151
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Originally Posted by LEX View Post
Curious. Where would one take rotors to shave down the hub?
Think any shop that does brake work could do it or would it have to be a machine shop?
Do it yourself with a grinder.
Keith
Convert to disc brakes.
lolife99 is offline
Old 07-29-2012, 12:01 PM   #1152
lolife99
lolife99's Avatar
These are pics from this thread.
Before and after,...
Keith
lolife99 is offline
Old 07-29-2012, 12:05 PM   #1153
lolife99
lolife99's Avatar
Here's a set of rotors that were machined for a set of 18's,...
Keith
lolife99 is offline
Old 07-29-2012, 03:40 PM   #1154
mrhino
boy, that pic sure looks familiar. yes, im thinking I had them done for $25
mrhino is offline
Old 07-29-2012, 03:45 PM   #1155
lolife99
lolife99's Avatar
Yes it's your picture.
I Googled "machining rotors for Boss 338 wheels",... and yours came up.
Much faster than looking at every page of this thread.
Keith
lolife99 is offline
Old 07-29-2012, 07:31 PM   #1156
Big Block 454
Big Block 454's Avatar
I'm with mrhino. When you see a set of these on a truck, you know the guy is resourceful.
And brossow is right about the hub of the wheel being thick. My 20x10 rears are so thick the lug nuts are down inside the wheel. (post 1131 on page 46 shows this)
Big Block 454 is offline
Old 07-29-2012, 08:05 PM   #1157
brossow
Amateur Rust Fighter
brossow's Avatar
Machine shop, or do it yourself with a grinder. It's not rocket science.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 07-29-2012, 08:29 PM   #1158
Big Block 454
True. But after spending that much money and having wheels that don't bolt on is frustrating.
And there are people that would just return them. I certainly considered it.
Old 07-30-2012, 08:39 AM   #1159
mcbassin
Still Learning
mcbassin's Avatar
HERE is another one with drawings.
I had a very early set of wheels so I had to cut the dust cover and weld it back together.
mcbassin is offline
Old 07-30-2012, 10:29 PM   #1160
Big Block 454
OK, with the help from this thread, I got the front wheels on today. A little machining on the rotors and the fronts went on - no problem with the grease caps on the rotors. The rears went on with no spacers. 18x8 with 255/55/18 fronts and 20x10 295/45/20 rears. Might have been able to get a 305 or 315 on the rear but might have needed to mini tub it.
I'm gonna try to post before and after pics that show the effort was worth it.
Old 07-30-2012, 10:32 PM   #1161
Big Block 454
P.S. I did not put the goofy chrome wheels on...they were on it when I picked it up a few weeks ago and I'm currently in the process of brnging te truck up to standards.
Old 07-30-2012, 10:40 PM   #1162
lolife99
lolife99's Avatar
WOW!
A hundred times better.
Very nice truck!
Keith
lolife99 is offline
Old 07-30-2012, 10:46 PM   #1163
brossow
brossow's Avatar
Presumably you've got the latest revision on those rears that has the extra meat on the back of the wheel, hence no need for spacers. Looks great! (And good job ditching those fugly wheels that were on it!)
Brent
brossow is offline
Old 07-31-2012, 01:09 AM   #1164
VA72C10
VA72C10
VA72C10's Avatar
Nice work on the truck! Major transformation with not only the wheels but also the rear! Love the change on the gate/bumper/trim!!!
VA72C10 is offline
Old 07-31-2012, 05:16 AM   #1165
mrhino
very nice! Worth the effort
mrhino is offline
Old 08-18-2012, 03:50 PM   #1166
Z10
Z10's Avatar
Need some help. A real nube to the forum and I've read this thread from the beginning.
I have a 72 Short Step that I would like to put these wheels on. Although I like the 20" look, I think I want to keep 18's all the way around. So, is this the spec I need for this truck? Currently the truck has not been dropped and not sure if I will drop it.
Front: 18 x 8"
Offset: +2mm, Backspace: 4.5"
AEWC part# 3382-9850-3AA
Rear: 18 x 9.5"
Offset: -5mm, Backspace: 5"
AEWC part# 3382-9950-3A
Looking to feel the wheel wells up a bit and I'm considering 255/18/55 tires all the way around. Does this look right?
Thanks,
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 08-18-2012, 04:09 PM   #1167
Big Block 454
The front combo will be exactly the same as what I used and my truck has about 3.5" drop in front and they fill the wheelwells. I would go with a little bigger tire in the rear. As for the backspacing, I don't think you can choose - they only have 4.5 on the 18x8 and 5 on the 18x9.5
Be ready to machine your rotors if you have disc brakes as was discussed here.
Old 08-18-2012, 05:42 PM   #1168
Z10
Z10's Avatar
Thanks BB454,
What tires did you end up using?
Looking at Nitto NT55 in Rear 265/50/18 Height 28.43 Width 10.83
Front 255/45/18 26.97 10.16
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 08-18-2012, 07:31 PM   #1169
Big Block 454
Originally Posted by Z10 View Post
Thanks BB454,
You can go to this site and compare different tire widths as well as diameters and sidewall height: http://www.discounttire.com/dtcs/infoTireMath.dos
Old 08-18-2012, 07:33 PM   #1170
mrhino
Front: 18 x 8"
Rear: 18 x 9.5"
yep! thats the exact combo I used on my truck. 245/45 up front 255/55 in the rear
mrhino is offline
Old 08-18-2012, 07:39 PM   #1171
Z10
Z10's Avatar
Nice truck Mike,
What brand of tires are you using?
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 08-18-2012, 09:31 PM   #1172
mrhino
Nice truck Mike,
Thank you.
I was running Federal Tyres. I didnt put a lot of miles on them before selling the truck, but I was very pleased with the tires. They handled great, no road noise and they did very well in the wet. Plus they have a bad ass tread pattern as u can see in the photos. I would certainly buy them again when the time comes again
mrhino is offline
Old 08-20-2012, 10:04 PM   #1173
lolife99
lolife99's Avatar
Has anyone ordered 20x8.5" Boss 338 wheels in the last few months?
Just wondering if the current part numbers have the 3AA designator, at the end of the part number?
Or if there is a new part number for the "current revision" of these wheels?
Keith
lolife99 is offline
Old 08-21-2012, 08:31 AM   #1174
eldogg
eldogg's Avatar
I'll look when I get to the shop. I ordered some for my brothers 65 GMC about 3 months ago.
eldogg is offline
Old 08-21-2012, 01:55 PM   #1175
hot trux
'85 Stepside
hot trux's Avatar
ordered two this morning....... then we compare!
hot trux is offline
Closed Thread
