Old 07-30-2012, 02:27 AM   #1
Red Foreman
Red Foreman's Avatar
WTB bed wood floor kit??
Where would be a good place to by a new Oak bed wood floor for my 56 GMC?
Has anyone had any experience with any of the vendors on this forum or maybe recommend another source?
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 07-30-2012, 08:36 AM   #2
Indian113
Indian113's Avatar
Re: WTB bed wood floor kit??
Red,I've been looking at the different bed kits and I feel Mar-K in Oklahoma has the best kit and nicest wood. They run sales all the time.
Indian113 is offline   Reply With Quote
Old 07-30-2012, 10:11 AM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
Given your location you might even look around for a wood worker you know and get some cool local wood to cut to size and finish. Buy some stainless from a vendor state side which should be easy to ship. Just a thought.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 07-30-2012, 11:12 AM   #4
Speedbumpauto
Speedbumpauto's Avatar
Bought all my hardware from Mar-K. They're great. Did the wood with a sheet of 3/4 inch 4x8 Oak veneer(sp) plywood but it's more of a show'er than a worker. Could save you a bunch on freight.
Speedbumpauto is offline   Reply With Quote
Old 07-30-2012, 11:27 AM   #5
Russell Ashley
Russell Ashley's Avatar
I'm with Brian on this one. Get the metal strips from Mar-K but get the wood locally. It's easy to make the boards and shipping a set from the states would cost more than the wood. I used GMCPaul's measurements to make mine.
Russell Ashley is offline   Reply With Quote
Old 07-30-2012, 11:58 AM   #6
OrrieG
OrrieG's Avatar
Cutting the bed wood is basically two passes with a dado blade or router, or a few more on a table saw and some chisel and sanding with a regular. GMC Pauls has good dimensions. Any one familar with woodworking could do them in an hour one they had the material. Making your own you can also adjust the spacing and number of strips like Speedbump did.
Old 07-30-2012, 10:39 PM   #7
Red Foreman
Thanks for the input fellas, I might call on a couple of local wood work/cabinet makers & get an opinion, hopefully one of them will have a routing tool that can cut in the same edge?
My Build 56 GMC
Old 07-31-2012, 12:19 AM   #8
solidaxel
solidaxel's Avatar
Red, Entourageuy nailed it !!
Look up a AD truck that came out 4-6 years ago, and he had his bed wood made out of African BUBINGA, you can make one with your local wood shops. just give them the measurments and your choice of wood.
I have used both SS hidden bolt bed strips, which one of them is located in Canada if shipping to Au. is different than Kansas.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-31-2012, 06:13 PM   #9
robin58
Red Foreman, no routing table really required although you can do it that way. Just as easy with a table saw. And a bunch faster.
Mar-K's website has the dimensions for the rabbet and kerf that anyone can pretty much follow.
robin58 is offline   Reply With Quote
Old 08-01-2012, 01:19 PM   #10
_Ogre
_Ogre's Avatar
it is cheap to make your own wood kit, stock is pine but any ''wood'' can be used.
like others have said, mar-k.com has the correct width and groove cuts on their site.
i used trex recycled plastic decking for mine, two passes on a table saw was all that is required.
shop air compressor timer
Old 08-01-2012, 02:59 PM   #11
mr48chev
mr48chev's Avatar
There should be some suppliers around Melbourne that sell interesting wood to the guys who build and or work on boats along with cabinet shops. We don't have one here but in the Seattle area there are stores that specialize in hardwoods and there my be one or more in the Melbourne area for that.
Ogre's top photo pretty shows what kind of cuts/trimming needs to be done but most people leave the rails slightly above the wood.
Old 08-01-2012, 04:43 PM   #12
_Ogre
_Ogre's Avatar
as mr48chev pointed out, i lowered my bed rails just under the surface to protect the paint
if you paint your bed rail recess them just a bit
ss, raise them up and it will protect your bed ''wood''
this is how i cut the trex
Old 08-01-2012, 05:00 PM   #13
01spirit750
I bought oak boards from Lowes and machined it myself with my table saw. The board dimensions are available thru various sources on the internet.
Chris
01spirit750 is offline   Reply With Quote
Old 08-01-2012, 05:10 PM   #14
mr48chev
mr48chev's Avatar
I never though of lowering them below the surface of the bed to do that Ogre. That would protect painted strips from the luggage, coolers and lawn chair that most of us carry.
Old 08-01-2012, 07:29 PM   #15
Maximus
Maximus's Avatar
lol - sad but true alot of our trucks shake their invisible head in shame
Maximus is offline   Reply With Quote
Old 08-02-2012, 01:14 PM   #16
_Ogre
_Ogre's Avatar
i think truk has seen it's last load of gravel
i do haul loads with it
Old 09-26-2012, 03:02 AM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great idea on lowing the rails a tad.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-26-2012, 09:33 AM   #18
Chevette
Chevette's Avatar
I'm with those who recommend purchasing the wood locally. If you buy it from North America you may end up with a load of propellers by the time you install it in your truck. Propellers with cracks, in fact. Humidity changes are tough on wood. I once shipped a load of hardwood furniture from Costa Rica to Calgary, put it in a warehouse and listened to it crack for over a year. Just sayin'.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 09-29-2012, 10:10 PM   #19
Red Foreman
Hello again, well I actually took some great advice from all you members & I sourced some locally produced 'dressed kiln dried tasmanian oak' that comes from the most sourthern island state here in Australia.
I down loaded the dimentions off GMC Pauls & gave them to an old friend of Dads thats is a retired cabinet maker, he was more than happy to cut & groove them for me.
Here are some pics with the first of three coats of Marine satin varnish, really happy with the natural colour of this timber.
My Build 56 GMC
Old 09-29-2012, 10:27 PM   #20
solidaxel
solidaxel's Avatar
GOOD CHOICE on colour and wood !!!
Now with all the money you saved, you can order some SS hidden bolt strips.
LS 3 4L70E
Old 09-30-2012, 06:19 AM   #21
Red Foreman
Solidaxel, is thats yours? It looks real good! My truck on the other hand is of the original patina variety & I didn't want to go real flash, although I did purchase unpolished ss strips from a guy on ebay, interesting that they were drop shipped from Oklahoma (Mar-K comes to mind) to my shipper in Long Beach Ca.
My Build 56 GMC
Old 09-30-2012, 07:46 AM   #22
Indian113
Indian113's Avatar
Red, That wood is beautifull-great choice
Old 09-30-2012, 07:56 AM   #23
solidaxel
solidaxel's Avatar
Yes Red that is one of my "fleet" of AD trucks.
I have Ash in the 55, Oak in the extended cab, and Cherry wood in the green 63 and Oak in the "new "54 and they were all cut and finished as part of the build, just like you are doing.
LS 3 4L70E
Old 09-30-2012, 12:12 PM   #24
_Ogre
_Ogre's Avatar
red; bed wood looks good.
the bolt kits from the truck suppliers are expensive.
short bed kits have the exact amount to do the job, but if you break one your screwed.
i bought boxes of 100 of the stainless 1/4x1.25 bolts, washers, locks and nuts for less than the standard steel bolt kits from boltdepot.com
i also bought ss fender bolts, step bolts, etc... at the same time.
Old 09-30-2012, 02:35 PM   #25
arturo7
arturo7's Avatar
I gotta question, where do I find the bed wood specs for a panel? Everything I've seen is for pickups.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
