Old 07-29-2012, 03:08 PM   #1
spyderbilt
Best fit stock exhaust manifold
Im ready to start purchasing swap items and need to know what stock exhaust manifolds work best in a 70 c20 2wd.
Im using an LS1 from a corvette along with a 2002 4l80e.
I have the corvette manifolds, just have not read about anyone using them.
GS
70' C20 CST
spyderbilt is offline   Reply With Quote
Old 07-29-2012, 08:50 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Best fit stock exhaust manifold
Trail Blazer SS manifolds are popular, you will need to trim the drivers side trans "wing" a little.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-30-2012, 10:20 AM   #3
Custom 68
Custom 68's Avatar
I used the ls6 Corvette manifolds. They worked and fit great. I then swapped to some mid length camaro headers they also fit good. I am now turbo charged so I went back to the stock truck manifold on the driverside.
I built my own mounts so it will be different for each different mount. I had read the corvette manifolds performed as well as headers so I used them. I did a littl trimming on the frame rails but it was minimal.
I say use them...
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-31-2012, 05:06 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
check out this thread HERE
Rich
1972 K5 Blazer CST Click HERE
Old 07-31-2012, 06:35 PM   #5
spyderbilt
Good info. Thanks.
I think i will end up building my own motor mounts and try to use the corvette manifolds. Im just concerned with motor mounts and manifolds interfering with my A/C compressor in the stock Vette location.
Any thoughts on moving the motor forward or back for tranny or any other clearances. Ill be using a 4l80e.
GS
70' C20 CST.
Old 07-31-2012, 09:52 PM   #6
BigShoe24
True Addiction
BigShoe24's Avatar
I've got a set off an LS3
RCC
BigShoe24 is offline   Reply With Quote
