Under the hood washing???
Can i do this at the local car wash by taking just a power washer to the inside of it or do i need to wrap or protect anything from doing this? i noticed that i have some dirt build up around most parts of the firewall.
Re: Under the hood washing???
I have done this several times at home (not at a carwash). Warm up the engine, take the air cleaner off and cover the carb opening with aluminum foil followed by several "walmart" style plastic bags. As long as you do not shoot water right down the carb, everything else should be fine.
#3 | |
Cover the Dizzy as well.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
Yeah cover the distributor and carb everything else a little water won't hurt.
78K & 79C Jimmys
after check the vac lines in case some came loose
try to use hot water it will cut the grease better don't spray the harness plug at the firwall too much,can blast right threw-
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
a big tip i haven't seen mentioned... when i cleaned my engine bay i was worried about the electrical stuff so i covered it.. and then i unhooked my battery cable so there wasn't power to anything and less chance of anything shorting out. But i also did it at hope with a power washer and let it dry well.
Rust is better than rice. ![]() |
I wash the engines in the daily drivers all the time (dusty around here).
I like to use a little simple green (deluted 50/50 mix) to help knock any grease loose then a mild rinse with the garden hose, I don't bother to cover anything, I'm just carefull not to spray directly at the air intake. I've done this for years and it's never bothered anything electrical or otherwise. I save the pressure washer for the bottom side of the car. |
Two main points. Cover sensitive components, and low pressure.
Covering components has already been mentioned. Like lap15 said, I like to use aluminum foil, then plastic bags. I also like to cover my alternator, there's too many holes in that thing, I don't want water getting in there and sitting. LOW PRESSURE. Many carwashes have an engine degreaser/tire cleaner selection, and it's usually low pressure. When rinsing, use the spot-free setting because it's also usually low pressure. Higher pressure can pull wires, loosen connections and vacuum lines, make it's way around seals, ect ect ect. If high pressure is your only choice, hold it further away so you're not blasting sensitive areas with full pressure.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#11 | |
#12 | |
CAUTION DO NOT USE Easy off oven cleaner and Mean Green together. Talk about cleaning.All the way to metal.
Don't ask me how I know. haha |
#15 |
Cruzzzn' Vet
I spray under the hood about 2/3 times a year to keep it clean, i'll spray the engine over with the soap and let it sit while I spray off the rest of the truck then come back and rinse everything down. Nothing is covered but I don't concentrate the spray on any elect connectors,been doing this for the last 25+ years with no problems
![]() ![]() Uploaded with ImageShack.us |
#16 | |
#17 |
I would have normally said go for it as I've pressure washed my engine compartment for years. Just last week I changed the power steering hose and had some oil on the frame from the work. Took it to the carwash and pressure washed everything real good and it turned out great......
Except, this time when I got the speed up a bit, I started hearing an exhaust spudder. What I think happened is spraying the exhaust manifolds too long with water and they warped slightly. I've also heard there is a potential of cracking them as well so be careful. Now, keep in mind that I am missing a bolt or 2 from my manifold so that could be the main culprit so hopefully I can just get some bolts and tighten everything back up. Just wanted to let you know...... |
#18 | |
#19 |
After I wash an engine and it dries I spray the entire engine compartment down with Armor All tire foam. As long as your not in the dust much I makes the engine compartment shine like new. It works especially well on newer cars and trucks with so much plastic under the hood.
#20 |
I would be careful..I got water in my engine compartment removing some plastic i used to cover my windshield while painting the inner doors and my electrical stuff went crazy! Luckily i just let it dry and all went back to normal
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#21 |
well i took it to the car wash this last saturday and mainly hit the back of the firewall and the frame along with the inner fenders just to hit all the grease and oil build up ( around the exaust maifold) and rust converted the mainfolds and turned out real good with no issues. i took pics but will post them up later.
