Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-31-2012, 06:20 PM   #7
SunSoaked
SunSoaked's Avatar
Re: 1969 k10 lwb to swb, 1 tons, 6.0/4l80e/np205
Nice build. I'm subscribed as I'm building a similar truck except longbed. I swapped in the whole suspension from a 87 M1008 (D60/14FF). If yours is out out a M1008 (Pickup) it should have a detroit locker in the 14FF. The "gov locs" were used in the M1009 (blazers).
Does your truck have factory A/C? It looks like it in the photo but the compressor has been removed. I'm trying to get a good photo of the pulleys/brackets on yours. Mine seems to have been peiced together by the PO. My crank pulley is a two piece unit with four v grooves and it sits about 3/8ths inch closer "in" towards the block than the water pump pulley so everything is off and I dont know where.
Anyway- looks like you have a great starting point and a nice place to work on it
SunSoaked is offline   Reply With Quote
