07-30-2012, 03:53 PM | #1 |
Power Steering
Ok so I just bought myself a LS engine to put in my 66. My question is that now that it has the power steer pump on it already I am gonna put power steering on my truck. What am I going to need, and who makes the best conversion kit. I want to use the orginal steering colum too. Another question I want to move my gas tank out of the cab, who makes a good tank at a good price. thanks in advance for any info.
07-30-2012, 08:49 PM | #2 |
Re: Power Steering
Tuffy,
Here is one way to do it with a LS motor. http://67-72chevytrucks.com/vboard/s...d.php?t=374519 CaptianFab (site vendor) makes a bracket kit as well and you don't have to drill out a hole in the PS box. Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-30-2012, 11:46 PM | #3 |
60-66 Nut
Re: Power Steering
Thanks for the recommend TR65
Here is the for sale thread for my power steering adapter plates. http://www.67-72chevytrucks.com/vboa...d.php?t=332923 For a gas tank, considering you are goping with EFI, I would recommend a tank by Dave Boyd. He is also a site vendor here. http://www.67-72chevytrucks.com/vboa...d.php?t=362307
07-31-2012, 09:52 PM | #4 |
Junior Member
Re: Power Steering
Make sure your power steering box is from a newer truck with metric fittings. Its easier to do when everything is metric. If i remember I used a box from a 86 c10 and ordered the high pressure line from year vehicle. The hard line has to be shaped a little but will come out between the fender and the frame. The metric line will bolt directly into the p/s box on the 5.3. I have had no issues at all..
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
