Old 07-31-2012, 01:42 PM   #1
Murphy IRE
Frt Leaf sprg 4x4 help
Here are pics of my current front leaf springs. As always she does fine off road, but on the Hiways, she as a small chatter type bounce/vibration. The driver's side leaf has gone concave and the right side is flat. The rear sets have plenty of spring and have a normal look. Are the front leafs supposed to be flat or are these dead? I had them worked on two years ago, but I think they have lost their spring. Should I replace? I have the std "highboy" suspension. I'm running 255 85r16 tires and I don't have any clearance problems. Thanks in advance.
Murphy IRE is offline   Reply With Quote
Old 08-01-2012, 07:51 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Frt Leaf sprg 4x4 help
Anyone?
Keith
Convert to disc brakes.
Old 08-01-2012, 08:11 AM   #3
jjzepplin
jjzepplin's Avatar
Chatter is not likely to be from the springs. Most likely from a warped rotor or bad tire or balance problem. However.. your springs should be about flat for stock. I would take it back to whoever "worked" on your springs and get that fixed. Also look into a stabilizer. They help a bunch on bigger than stock tires and stock.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-01-2012, 10:29 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Murphy IRE I'm going to move this to the 4x4 forum to see if you get a more input.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-01-2012, 10:38 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Never saw a stock setup with that many springs.
They are flat or negative arch when stock. And I agree, springs dont cause chatter or vibration. Mabey a wore out shock, spring bushings, tire out of balance, loose or bad wheel bearing, ball joint, etc. Jack it up and start pulling , prying, and wiggling stuff till you find the culprit.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-01-2012, 12:49 PM   #6
Murphy IRE
Shocks are 1yr old Rancho 5000. I'll check the wheel balance and then start playing. I'll take it back to the spring place and have them check out the difference between the two sides.
Old 08-01-2012, 03:40 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Agreed. Those 5-leaf springs look about the same as my 2.5" Softrides.... about the same gap to the rubber bumpstops too, though I think my gaps may be a bit larger.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-01-2012, 07:25 PM   #8
obijuan
youve got red poly bushings, those are definately aftermarket. and a little wore out.
describe the noise in ten words or less lol. and just because those shocks are a year old doesnt mean they are still good.
obijuan is offline   Reply With Quote
Old 08-02-2012, 12:32 PM   #9
OldCreek
OldCreek's Avatar
With 5 leafs in that driver side pack I'm surprised it has gone negative....take it apart and see it a leaf if cracked/broken. The stock 2 and 3 leaf packs I've seen have gone negative, however. I have a 4 leaf pack that is flat.
Check your ball joints, btw....all of them.
Rebalance your wheels and, remember, you're riding on MTRs!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 08-02-2012, 12:56 PM   #10
Murphy IRE
All good advise, Iwill will keep you posted as I get the work done.
obijuan
No Noise just a constant vibration/bumpy ride; worsens as speed increases.
Old 08-02-2012, 05:26 PM   #11
69GWC
Did you swap tires from front to back to rule out a bad tire or bad rim?
69GWC is offline   Reply With Quote
