Old 07-10-2012, 03:54 PM   #526
truckmanloco
Re: Project "Funky Monkey"
Have you looked at the timing it sounds like the valve is staying open and filling cylinder with fuel. Maybe thats why its not turning over to much fluid pressure in the cylinders. Then the fuel is just leaking by the rings back to the oil pan . As for the fuel in the headers maybe the exhaust valve timing be off is allowing the fuel to drain straight to the exhaust. Just my thought hope you get it fixed.
truckmanloco is offline   Reply With Quote
Old 07-11-2012, 06:24 AM   #527
funkytechmonkey
funkytechmonkey's Avatar
I got the truck running and drove it home from the shop....when I turned it off it acts like it doesn't want to turn off. That could be it.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 07-11-2012, 06:31 AM   #528
kikkegek
kikkegek's Avatar
read you previous post...really weird. goodluck fixing/finding the problem...
kikkegek is offline   Reply With Quote
Old 07-11-2012, 09:32 AM   #529
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
That flooding almost sounds like a float issue with the carb?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-11-2012, 11:50 AM   #530
Mike Bradbury
Mike Bradbury's Avatar
Do you have an electric fuel pump? Sounds like it is not shutting off and just continuing to run when the truck is off.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 07-11-2012, 01:19 PM   #531
Jarwood
Jarwood's Avatar
I have an electric pump and had the similiar issue. Kept trying to start it and all it would do is turn over. Come to find out, the coil went out. Fuel went into the cylendars and would not even turn over. Pulled out the spark plugs and gas poured out. Cleaned it all out, changed oil, and replaced coil and runs great again.
Jarwood is offline   Reply With Quote
Old 07-11-2012, 03:45 PM   #532
funkytechmonkey
I do have an electric pump that is built into my boyd welds tank... But I am running a carb, so I installed a fuel pressure regulator that has a return on it. When I had the EFI on there the pump would run for a few seconds when I turned the key on but now it just runs constantly until I turn the kay all the way off. A friend of mine was saying that is not a big deal because now it will just keep circling thru the return.... That true?
Old 07-11-2012, 04:02 PM   #533
Hart_Rod
Hart_Rod's Avatar
Originally Posted by funkytechmonkey View Post
I do have an electric pump that is built into my boyd welds tank... But I am running a carb, so I installed a fuel pressure regulator that has a return on it. When I had the EFI on there the pump would run for a few seconds when I turned the key on but now it just runs constantly until I turn the key all the way off. A friend of mine was saying that is not a big deal because now it will just keep circling thru the return.... That true?
Thats true. What pressure do you have your regulator set at?
Hart_Rod is offline   Reply With Quote
Old 07-11-2012, 07:31 PM   #534
funkytechmonkey
I have a pressure gauge on it and it reads 7 psi when its running.
Old 07-11-2012, 09:21 PM   #535
Hart_Rod
Hart_Rod's Avatar
Sounds a little high (I usually set mine between 5-6 psi) but I don't think that would have caused the problem.
Old 07-14-2012, 01:35 AM   #536
Mike Bradbury
I would think if a cylinder is filling up with fuel then the bypass valve is not bypassing 100%. Maybe there is a siphoning effect going on. Do you have a breather type gas cap? With the gas tank below the level of the engine, there is only a couple of ways that the fuel can get into the cylinders; pressure or suction.
Old 07-14-2012, 01:58 AM   #537
insane04
love the truck. wish my project would move that quick.
insane04 is offline   Reply With Quote
Old 07-20-2012, 08:16 PM   #538
Hart_Rod
Hart_Rod's Avatar
Update?
Old 07-22-2012, 02:45 PM   #539
perenf
Nice Truck. I am restoring an Orange and White 72 Chevy Shortbed and live right off of McGinnis Ferry Rd in Suwanee. I think my wife and I will swing by the restaurant on 8/18. I wish mine was running so I could bring it with me. Very near starting it but have paint and body to finish etc.
perenf is offline   Reply With Quote
Old 08-03-2012, 06:45 AM   #540
suspect
suspect's Avatar
you mentioned you painted your rotors a high heat black paint. well, my rear rotors came in and they have that E coating on them, so i'll have to paint the front for sure now to make them match. what paint did you use? it obviously has to be some kind that comes right off once you brake.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 08-14-2012, 10:30 AM   #541
funkytechmonkey
Suspect... I went to home depot and got just got a rustolem gloss paint that pretty much matched the e-coat on the back. It came off pretty smooth and looks great. I was thinking I may need to use a high heat but it this one has worked fine.
Alright.... So here is my latest update!!!
I got really hed up with the carb and the older Holley TBI so I went ahead and took the plung and got a brand new Ez-EFI setup. This thing was VERY easy to install and I am pretty pleased with the way it has turned out. I had to run a new return line and extend the feed line. Before I had the fuel lines coming from the rails behind the motor and crossing over the headers, they were pulled off of them but I didnt like how it was run over the top of them. Now they are runing from the rails down the front of the motor and down the frame never crossing the headers.
So the EZ-EFI install. The install was pretty simple. But after the install I had a few problems. I wasnt getting any fuel to come out of the injectors. I was blaming the fuel pump, fuel pressure and even the filter. Come to find out... I needed a fuel pressure REGULATOR. Another rookie mistake. The lines had enough pressue puming the gas in the rails and thru the returns but I didnt have any back pressure. So I made a little bracket and installed the regulator and bam... it fired right up.
After getting it to run it would never go into the "learning" stage. The hand held kept throwing up a code for the O2 sensor. Problem solved by charging the battery. simple. So I start driving it... hoping it would learn and start running better. But it nevers sounds right and its constantly backfiring. So yeaterday I had the first professional shop look at my truck. Come to find out there were several things that had gone wrong that caused all of these problems.... 1- I must have tightened down the temp sensor too tight and broke it. My temp guage on the EZ-EFI always read 255. The mechanic used a laser temp sensor and said it was 130, replaced that and put the sensos in a better location. One problem down. 2 - The alternator was killing my batter and not giving me the 13v I needed whem my compressors kicked on. We changed the alternator to a more beefy one 110v i think is what it was. That was the most expensive part of the fix but worth the extra money. 3 - one of my plug wires had melted from being too close to the header... replaced that and we fired her up. It was running so much better but not perfect. He adjusted the timing and MAN IT IS AWESOME!!!!.
I am so glad I took it in. They were able to find these issues that I was not able to see and they fixed them fast. Now mu truck is running perfect and I can get back to driving her.
Old 08-14-2012, 10:34 AM   #542
funkytechmonkey
Over the next few days I will be detailing the crap out of her to get ready for my car show this Saturday at my restaurant. After I am done cleaning her up I will take a bunch of pictures and post them up. I am pretty excited now that my truck is running so good and everything is working properly. I will drive her for a while and them start working on all the body work.
Old 08-14-2012, 10:48 AM   #543
Mike Bradbury
Looks awesome! How much did the EZ cost you? last time I looked at them at the good guys show it was almost as much as all the upgrades I had put in my engine! Is it worth it? Were you after better gas milage or better perfomance?
Old 08-14-2012, 11:04 AM   #544
kikkegek
kikkegek's Avatar
hahahaha, gogogo...love the EZ-EFI setup...carbs are nice and retro...but nothing beats a good EFI setup!
Old 08-14-2012, 11:49 AM   #545
funkytechmonkey
I got it from Summit... they matched a price I found online so I got it for like $1100. Plus I had a bunch of stuff to return so I had like $400 in credit with them and $80 in Summit bucks. I came out pretty good on it.
For me being a complete rookie to all of these it was a pretty simple install. All it really needs to run is a tack reading, fuel pressure and a good 12v connection.
After fixing everything yesterday it runs PERFECT. The throttle responce on it is incredible. I love this thing.
Old 08-14-2012, 01:01 PM   #546
VA72C10
VA72C10
VA72C10's Avatar
Cool deal! Glad you're getting to enjoy it now! Looking forward to the cleaned up pictures.
Old 08-14-2012, 06:51 PM   #547
oldman3
oldman3's Avatar
I've been wanting to go to the EZ-EFI, but a friend of mine had lots of problems with his, kept going into the "leap mod", took him awhile to sort it out. So I've been waiting to hear if someone else has switched. I know performance is much better, lets us know if the mileage is any better (if you keep your foot out of it)...Jim
oldman3 is offline   Reply With Quote
Old 08-14-2012, 06:54 PM   #548
funkytechmonkey
I can already tell just from two days of driving back and forth to work that it is going to be tons better. I will start keeping track of it so I can get my actual milage.
Old 08-14-2012, 07:43 PM   #549
suspect
suspect's Avatar
i was just talking to someone about the EZ-EFI a couple days ago. i was debating on getting one, but was wanting to see some reviews on it. looks like i will for sure be getting one now.
Daniel
Old 08-14-2012, 07:51 PM   #550
funkytechmonkey
I reccomend it... find a price online and have summit match it.
