06-26-2012, 10:06 PM | #1 |
Anyone know where to find this part?
In preparation for sandblasting and painting, I completely disassembled my clutch/brake pedal bracketry. In doing so, I seem to have ruined one of the white plastic sleeves. I have been looking at many aftermarket sites but so far, no luck. Does anyone know if these are even reproduced? If not, I suppose I will try a wanted ad.
Here's a pic of the 3 sleeves I removed. 2 seem ok. 1 is unusable. As always, thanks for your continued support and knowledge. Tony
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org Last edited by tow guys; 08-02-2012 at 05:09 PM. |
06-26-2012, 10:18 PM | #2 |
Re: Anyone know where to find this part?
I was able to get them for my 85 thru the dealership....yours look very similar.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
06-27-2012, 01:20 AM | #3 |
If you find them, post it so I can order some too.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
06-27-2012, 04:42 AM | #5 |
i'd look in the hardware section of ace hardware
06-27-2012, 06:25 AM | #6 |
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-27-2012, 07:19 AM | #7 |
Thanks Dan! I really appreciate the link
Tony Posted via Mobile Device
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
06-27-2012, 08:58 AM | #8 |
No prob, just busy "working" Now that I am awake where did the third one come from, I only found two taking my clutch assembly out of the brake bracket? it maybe different. Pic shows where mine had two.
06-28-2012, 09:40 AM | #9 |
I suppose it came from the brake pedal as I found 3 total when I completely dissassembled the assembly.
06-28-2012, 03:19 PM | #10 |
Project Junkie! Fishing Poor!!
We have a few pairs in stock also. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-02-2012, 05:04 PM | #11 |
Wes, I sent you a pm regarding the parts you shipped.
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org Last edited by tow guys; 08-02-2012 at 05:10 PM. |
08-03-2012, 09:39 AM | #12 |
It seems there are actually 4 of these plastic bushings in total. 2 are on the clutch pedal rod that are 3/4" in diameter and 2 more on the brake pedal rod that are 1"divider in diameter. Turns out I needed the 3/4" sleeve size that Wes sent me.
Thanks Wes! A pm is on the way buddy.... Tony Posted via Mobile Device
