Old 08-05-2012, 07:59 PM   #1
76k10
Off-Road Brake Discussion
Okay, so a few months ago I redid all the brakes on my K10, and had great brakes. Now the rear drums are completely shot and front discs squeaking like crazy. I have only driven the truck a few hundred miles, but it has gone through alot of mud.
I swapped in ceramic pads in the front and cut drain holes in the bottom of the rear drum backing plates.
What are you guys doing to make your brakes last?
76k10 is offline   Reply With Quote
Old 08-05-2012, 09:01 PM   #2
69GWC
Re: Off-Road Brake Discussion
If you drive in a lot of mud and water not to much you can do, mud is liquid sand paper to brake pads.
I have a atv that all it does is go through mud and water and it eats brake pads about every 100 miles or so.
69GWC is offline   Reply With Quote
Old 08-05-2012, 10:14 PM   #3
obijuan
Wash it.
obijuan is offline   Reply With Quote
Old 08-05-2012, 11:50 PM   #4
x ReAcT x
^ x2
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 08-06-2012, 07:50 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Convert to disc's on the back.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-07-2012, 11:47 PM   #6
Mr. 250r
Mr. 250r's Avatar
I never had any problems with drums and mudding through a whole lot of water my brakes were always good but i also took the hose thoroughly to the brakes after i was done but i absolutely hated after it rained my rear drums would be so touchy it would put me against the windshield, converted to rear newer FF with drums now
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
