#201 |
Re: Br3w City's Project omgwtfbbq
what shifter are you getting? i was thinking about the "twisted shifter" if i dont get a 16" floor mount lokar!! i like the idea that he builds were you can lock them out, and since i got bench seats the other shifters he has wont really work! he use to have one that was called the "military" shifter that would have worked but i havent seen it the last few times i looked them up!! i thought about getting ahold of him to have one built, like combine a two of them , heres the link to the twisted shifter:
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 Last edited by chad64chevy; 07-01-2012 at 05:47 AM. |
#202 |
meowMEOWmeowMEOW
Mine is similar, but I don't think it has the twist. Similar style but with slightly larger holes in the plate, no twist, and an 18" lever. I had it setup with a reverse lockout, and to accept the Epco knob that I had made already.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#203 |
ya i think you got the stick shifter model! this one??
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#204 |
meowMEOWmeowMEOW
Yep, but powdercoated black and set up for a 4spd with an NHRA manual reverse lockout lever.
#205 |
meowMEOWmeowMEOW
Its been mostly more sanding on the doors as we inch towards paintwork.
I did get my rollpan in from Mar-k, and fitted and riveted it on. Took a whopping 15 minutes. ![]() ![]() ![]()
#206 |
meowMEOWmeowMEOW
Most bodywork again today; shaping sanding etc. I haven't continued to picture that, since it all looks the same and there isn't much to be learned or gained from those photos.
That said, on the useful side of things I did get something accomplished. My tach wasn't working since my Lq4 swap. Its an Autogage Tach, by Autometer. I had it hooked up like normal, but found out that it needed a resistor added to the circuit to make it work correctly. This info was originally posted in a thread called "regular tach on LS2" or something similar. Basically, it just requires adding a 1/4watt 1000ohm resistor to step up the voltage the tach gets from the signal wire. The resistor gets wires across the signal and power wires, and works very well. It was a cheap fix, and I have 3 left over from the pack, if I ever need to do it again. ![]() ![]() CLICK for video if you care...I was just happy it was working, and wanted to prove it. ![]() ![]()
#207 |
meowMEOWmeowMEOW
STILL WAITING ON MY KILDUFF SHIFTER. THIS THING BETTER BE AWESOME OR I'M GONNA STICK IT SIDEWAYS UP HIS A$$. I sound harsh, but when I placed the order, he said I would have it in my hands UNDER 2 weeks. After 2 weeks I called, and it hadn't been finished, let alone shipped. He said it would be out the door that day...Week 3 has come to and end.....and no shifter. Dude if you want a successful small business, keep your word.
Anyway....since paint is bout to happen, it was time to start some of the tasks. Pulled out the rear window and cleaned up some loose debris. Then it was time for Visqueen and staples to make the "operating room". In person it looks cool with the lighting and the silver floor with white walls. Cleanest its ever been....and my brother wandered into the pic. ![]() ![]()
#208 |
Looks like you are going to go all "Dexter" on your truck in there!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#209 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Is it me or does that shifter go from 3rd to reverse with no lock out????
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#210 |
meowMEOWmeowMEOW
the one in the video posted doesn't lock out any more than normal "resistance" would prevent it....however mine has an actual NHRA manual lockout lever.
#211 |
meowMEOWmeowMEOW
Whew, I'm tired as all hell but we got some progress!!! Started early (and damn it was SUUUUPER HOT again today), rolled the truck out to give it a dawn wash to remove an road grime, and do some final dry sanding to remove any loose rattle can paint left on the truck, clean off any flash rust and make sure everywhere was ready for prime.
We blew it and dried it off, then put it back in the "booth" (after giving the booth a wet down and brush out) and hit the truck with some wax/grease remover / surface cleaner stuff. After over an hour of taping we Threw on the hazmat suits, gloves and respirators, and got to work mixing up some epoxy prime to shoot. It was 1 light coat, followed by a medium wet, going with nearly an extra coat on filler areas for soakage. It took a good while and the heat was a challenge, but it ended up laying out pretty decent once we played with gun settings. The reducer was a bit touchy because of the heat, but with planning we kept an edge and it all seemed to work out. Sooooo much more work yet to do, but major progress (also coated the wheelwells with bedliner, but that seems minor in comparison. Ok .Pic Dump. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#212 |
Awesome !!
#213 |
meowMEOWmeowMEOW
Kilduff shifter finally came. Looks pretty good (garage engineered, but thats not really a bad thing). The mechanism feels pretty good from what I can tell. I may have to switch bracket types according to the instructions (didn't tell me this) but won't be able to know until the truck is back out of paint. Excuse the weird FLIR effect on the one photo and in the video, my phone is a spaz.
![]() ![]() ![]() ![]() ![]() ![]() vid ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 07-20-2012 at 10:44 PM. |
#214 |
Still Learning
Looks like you're moving right along on the bodywork. Congrats on the shiifter.
#215 |
meowMEOWmeowMEOW
Another day out in the "booth", laying down a few coats of build primer. I didn't bother with pics, it still looks like a gray truck lol. Looks like a weekend of blocking in my future.
I did get a delivery however. Although I don't have any sponsorships, I did get a little hookup thru kicker. I'm still waiting on my 6.5" components, but my 6x9's for the doors, dx400 amp and hookup stuff showed up. ![]() ![]() ![]() ![]() ![]() ![]()
#216 |
Oooooooo ..... nice !!
I am contemplating Pioneer speakers here, just because Wal-Mart sells them LOL. I dropped $2,100.00 of sound into my Tempest. Pretty sure the wife would lynch me if I tried that with this truck !!
#217 |
meowMEOWmeowMEOW
Pioneer makes some good stuff, just gotta see what part numbers they carry. Wal Mart has a tendency to get major manufacturers to make down-market versions of their product. I.e. make sure that its actually rated at what its supposed to be. They do it with Tv's all the time.
I've had a few rather robust systems, but either sold them with the vehicles, or pieced them out over time. I don't have my invoice but not counting the L7 which isn't "for sure" in the plan yet, we have give or take ~$1k worth of stuff, which I think I picked up for about $205, I couldn't complain. Audio is crazy expensive, and even the MSRP on what I have is still conservative by big audio standards. Guys that start going with Focal, high end MB Quart, the higher lines of JL etc, AND start adding multiple subs, staging, Eq's are in the 5-10k$ and up. This is an old, LOUD truck, with sound deadening that although much improved, will still sound like an old, loud truck. We just wanted to be able to enjoy music over the exhaust, and actually understand what people were saying ![]() Should have more progress for yall later this week or so.
#218 | |
I dropped so much into my Tempest because it is a convertible, and I wanted to make sure I could not only hear the music with the top down doing 70mph down the highway, but I want to enjoy it too. I am not that guy that likes loud music for the sake of being loud. I dont particularly want to share my toons with everyone in the neighborhood, but clarity is key. With the way I configured the sound in the Tempest, with the amount of speakers, and the power behind them, when you sit in the back seat of that car with a well engineered song playing, you actually feel like you are IN the band! I love it!! PM sent, sir.
#219 |
looking good Ill keep watching for more its giving me some ideas .
#220 |
meowMEOWmeowMEOW
Well since I'm STILL FREAKING BLOCK SANDING DAMN!T
The only thing worth posting is that my 6.5" components came to match the other kicker components I mentioned earlier. ![]() ![]() ![]() ![]() ![]()
#221 |
meowMEOWmeowMEOW
FINALLY.....another bunch of LONG days but...COLOR!
We had to run around to pick up some crap I forgot as always (buy 1.5 times the amount of reducer you THINK you need....and then remember you use it to clean the guns, other stuff, and to over reduce epoxy for sealer. We got the epoxy all reduced for sealing (about recommended plus ~20% extra reducer). Shot one coat of that, let it setup for about 10 and came back wet with color. Yes its a f*rd color, but they didn't make good use of it ![]() We did have 1 stupid run....because we clogged the air hole in the top of the hvlp and it spat solvent out damnit! We have to fix that in a couple once it hardens. I know my body isn't show-quality, and the paint isn't perfect....but I'm damn proud of what we did in a garage. Ok, enough excuses, time for pictures (many more to come after it cures) ![]() ![]() ![]() ![]() ![]() ![]()
#222 |
For a ford color that looks pretty sweet!! Nice work
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#223 |
Agreed! Coming along really nicely
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#224 |
Still Learning
Nice work on the paint! I bet you were pumped to finally gets some color on it. More pics....
#225 |
Kvn1011
Awesome!
![]() ![]() (Project Slow Motion) |
