Old 08-06-2012, 05:13 PM   #1
zebco
drop spindles rubbing 15" rim
I do not know what spindles I have. They came in a package deal. I just mounted my 8" truck rallys and the lower a-arm and the steering arm are extremely close to rubbing. If I turn the wheel to lock in either direction they will lockup on the lower a-arm. They have the casting #'s G M T 130-90 and 218-90 respectively. I'm kinda bummed on this. Any info out there? Thanks a heap and a whole lot in advance.
Herb
zebco is offline   Reply With Quote
Old 08-06-2012, 05:16 PM   #2
Clyde65
Clyde65's Avatar
Re: drop spindles rubbing 15" rim
From what little I know, the edge of the LCA is going to need to be clearanced about 1/2-3/4 inch. you can do this with a grinder.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-06-2012, 05:17 PM   #3
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Yep, this is common with lowering spindles/15x8s on chevy trucks.
ProStreet68SB is offline   Reply With Quote
Old 08-06-2012, 05:41 PM   #4
zebco
I was thinking the same thing and also adding 1/4" spacers to each side.
Old 08-06-2012, 06:02 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
This is VERY common on any 15" wheel with more than 3.5" backspacing.
Your 8" ralley wheels have a 4" BS.
Just trim the lower a-arm with a grinder.
Takes about 5 minutes per side.
Keith
Convert to disc brakes.
Old 08-06-2012, 06:11 PM   #6
stomper
Junior Member
stomper's Avatar
I also was unaware of this on my build before I bolted up the 8" ralleys and had to clearance the LCA's. There are threads in here with photos so you can see what you're in for. It took me more than 5 minutes.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
