Old 08-06-2012, 03:11 PM   #1
chevy355
Question 454 mileage
i found a 454 at the local pick and pull in a '89 suburban. i know they like there gas but i was curious what kind of gas mileage i would get with a 454 carb,nv4500 trans,4.10 ratio, and 33 inch tire?
Matt
1986 chevy K10 355, sm465/np208, 14FF/dana 44
1984 chevy K20 350, th400/np208, 14SF/10 bolt
chevy355 is offline   Reply With Quote
Old 08-06-2012, 03:46 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 454 mileage
What mileage? Hope you have two tanks!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-06-2012, 03:50 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Re: 454 mileage
I think it might be mathematically easier to calculate that combo in feet per gallon. Haha.
Realistically though, you can probably expect 8-10 mpg.
Old 08-06-2012, 06:59 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 454 mileage
Every 454 ive been around gets 10 driving right. Dramatically less heavy footed
Old 08-06-2012, 07:24 PM   #5
C-10 simplex
Re: 454 mileage
i've stated it before. i will state it again:
BIG BLOCK ON THE STREET = FINANCIAL SUICIDE
i think the only way you can get any decent mileage out of a big block is to utilize very high compression----14.1-to-1 if that's even possible----which would necessitate using water injection (or as high compression as possible), headers and hi-gear such as 2.56.
C-10 simplex is offline   Reply With Quote
Old 08-06-2012, 07:42 PM   #6
chevy355
Re: 454 mileage
well now im running 355 with 11.5 to1 comp ratio through a sm465, 308 gear ratio and 33 inch tires and im running 7.5 mpg and thats driving with a light foot. the reason i wanted a 454 was for torque
Matt
Old 08-06-2012, 07:48 PM   #7
meter swinger
meter swinger's Avatar
Re: 454 mileage
My TBI crew dually gets around 9mpg/empty/loaded/pulling seems not to make much difference. I get a little better on flat hiway and a little worse going over the mountain passes here in WA.
FWIW It is thirsty but then im not paying making payments on a 50k $$$ diesel truck i would only drive every other weekend. Total operating cost is actually pretty low if you look at it that way.
meter swinger is offline   Reply With Quote
Old 08-06-2012, 07:49 PM   #8
C-10 simplex
Re: 454 mileage
What are trying to do? Towing?
Old 08-06-2012, 08:10 PM   #9
i8tokyo
Re: 454 mileage
My 82 C-20, 454, TH-400, 4:10 gets 10.2 mpg whether I'm towing, loaded down or empty. My 1998 C3500 ext-cab dually, TBI 454, 4L80, 4:10 gets 10.8 empty and 8.8 towing a 8200lb trailer and boat.
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles
1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles
If it ain't broke, there is still probably room for improvement.
Speed costs money, how fast do you want to go?
i8tokyo is offline   Reply With Quote
Old 08-06-2012, 08:16 PM   #10
chevy355
Re: 454 mileage
i live on a dairy farm so it tows wagons and a trailer for my classic tractors
Matt
Old 08-06-2012, 08:57 PM   #11
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: 454 mileage
Street/highway/empty/loaded/uphill/downhill/sea-level/high altitude = 10mpg. Period.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 08-06-2012, 09:01 PM   #12
russgt
russgt's Avatar
Re: 454 mileage
If you shut it off going downhill you might get a little better, LOL
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-06-2012, 09:05 PM   #13
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: 454 mileage
Had a 454 in my stepdads 67 Chevelle before we sold it. Edelbrock intake, Holly Carb, 3:73 gears and TH400 later swapped to a Muncie 4 speed. Got pretty much 8 the whole time. Maybe 10 downhill, not running, with a tailwind and on a trailer....you get the point....
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 08-06-2012, 10:17 PM   #14
100%Chevy
Re: 454 mileage
About the same here.
82,4x4,454,t-400,with 373 rear.33x12.50 tires.
The only good thing is,it gets the same milage up hill or down!
With or without our 28'travel trailer.
9 to 11 per gallon is about normal.
BUT,nothing beats it for towing!
Mike./
100%Chevy is offline   Reply With Quote
Old 08-06-2012, 10:53 PM   #15
78 Big10 454
78 Big10 454
Re: 454 mileage
But no power steering/brakes!
Old 08-06-2012, 11:03 PM   #16
mopar346
Re: 454 mileage
How bout the 2005ish 8.1 with an allison?
mopar346 is offline   Reply With Quote
Old 08-07-2012, 01:08 AM   #17
tucsonjwt
Re: 454 mileage
My 83 C20 2wd reg cab LB best mileage with gear vendor used frequently got 11 mpg city, 13 mpg highway. Realistically, I get 9 mpg city in constant stop and go traffic (the only place I drive now.) The lowest I got was 8 mpg city hauling dirt in my dump conversion. However, the 76 C20 350/350 did not get any better gas mileage. I think when you are hauling around an extra 1000 lbs. of dead weight compared to a 1/2 ton you are not going to get good gas mileage even if you had a 4 cylinder.
tucsonjwt is offline   Reply With Quote
Old 08-07-2012, 01:31 AM   #18
king-918
king-918's Avatar
Re: 454 mileage
2 gallons = 1 mile
king-918 is offline   Reply With Quote
Old 08-07-2012, 02:17 AM   #19
cory d
cory d's Avatar
Re: 454 mileage
get the nv4500, leave the 454
cory d is offline   Reply With Quote
Old 08-07-2012, 02:30 AM   #20
andrewmp6
Re: 454 mileage
Why not do a diesel swap? a 6.2 will bolt in have enough torque and get better mileage.
Old 08-07-2012, 02:30 AM   #21
INSIDIOUS '86
Re: 454 mileage
Ok here I propose a idea that isn't employed often
Cummins 6bt swap, the torque and fuel mileage you need and planty are available
Old 08-07-2012, 07:35 AM   #22
redsled87
redsled87's Avatar
Re: 454 mileage
Guess I'm screwed then with the 496 that I built. Oh well, I built it for speed not for economy. I know that some stock 396's that get good mileage. My parents have a '66 Caprice that is a bone stock 325hp that, they have gotten 20mpg out of. But it also has 2.73 gears in it too.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 08-07-2012, 07:41 AM   #23
BigBlocksRule
Re: 454 mileage
If you can set it up in front of a 4L80E, it will help a lot!
And for all you diesel swap supporters...I can completely overhaul a 454 for less money than you can have a diesel injection system rebuilt. And if I add a turbo similar to what comes stock on most diesel engines, I'll out pull 'em and shave 400lbs off the nose of my truck.
BigBlocksRule is offline   Reply With Quote
Old 08-07-2012, 07:48 AM   #24
redsled87
redsled87's Avatar
Re: 454 mileage
I wouldn't swap to a diesel either. For what he is doing, its not worth it. Alot of money for nothing. Maybe he could find an '01 and up 8.1 instead.
60' 1.49
1/4 10.93
MPH 120
Old 08-07-2012, 09:06 AM   #25
C-10 simplex
Re: 454 mileage
Are you going to tow the tractors off-farm or on-farm?
4.10, 454, big block, nv4500, truck
