Old 08-07-2012, 01:39 PM   #1
JJAB
4L80E? Will It Work?
Guys give me a little information, PLEASE!!. I have a 4l80E GM Goodwrench replacement transmission that was pulled off of a 1995 chevy dually. My question is, I have a 2002 6.0 DBC swap that needs a transmission to complete the package. Will this tranny work okay? The only visible difference that i see is that on the driver side of the tranny, it does not seem to be a place to bolt the gear selector module. Is this needed to retro this package in an older vehicle. Anyways, please chime in!!!!!!!!!!
JJAB is offline   Reply With Quote
Old 08-07-2012, 03:20 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4L80E? Will It Work?
iirc the gear position indicator isn't needed, all it does is tell the vehicle what to display for "gear" on the dash....older trucks didn't have the digital readout.
you will have a bolt hole that doesn't line up, which is fine. (top one)
you'll probably want a new tq converter, and if it was a diesel iirc you NEED a different converter.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-07-2012, 04:47 PM   #3
JJAB
Thank You for information!!!!
Old 08-07-2012, 04:59 PM   #4
Super73
Super73's Avatar
You mayalso need a new internal harness andtemp sensor
My 93 80E required both since the earlier 80E had a different wiring harness plug.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-07-2012, 07:57 PM   #5
clinebarger
91, 92 and early '93's had the weird bolt-on connecter & harness.
I do recommend replacing the EPC solenoid with a new one from GM, A bad EPC can cause "sky-high" line pressure...And can even break the case, Cheap insurance when dealing with a early 4L80E.
clinebarger is offline   Reply With Quote
Old 08-07-2012, 09:39 PM   #6
Super73
Super73's Avatar
Now that I think about it, I did change one of the solenoids too. How you forget things after 7 years.
Old 08-08-2012, 12:00 AM   #7
Mr. 250r
Mr. 250r's Avatar
My 05 wiring harness fit perfect in my 91 4l80 if we're talking that big bulk plug on the side of the tranny
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-08-2012, 12:24 AM   #8
clinebarger
It was updated to the newer harness, The old harness is NOT seviced by GM or any aftermarket supplier, Its rare to even see a early harness.
