Mysterious bracket on throttle pedal
Hey all, there's a bracket (which nothing's connected to) mounted to the throttle pedal.
![]() ![]() (First picture is the bracket-second is where it bolts on to) Any idea what it's for? Thanks!
71 K20 64 GMC mud truck |
Active Member
![]() Join Date: Jul 2007
Re: Mysterious bracket on throttle pedal
Can you post a pic of it attached? It would be easier to determine what it may be used for if no one else has seen one before.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Sure...not on right now but it looks challenging to get on
Possibly some sort of after market cruise control set up?
Posted via Mobile Device |
All I can tell you is that I just took apart my truck, every nut and bolt, and didn't come across that piece on my '70 3/4 ton. Perhaps aftermarket cruise?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#6 | ||
"I ain't nobody, dork."
Bolt it back on and then take another pic.
Gary
Its for a kickdown switch for a TH400 trans.
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#9 | ||
Nevermind!
![]() Gary
Active Member
huh? Mounted on the gas pedal? I guess I've never seen anything like that before on the pedal.
Moderator
71-72 the kickdown was mounted on the pedal.
Active Member
I was thinking it was attached to the pedal lever itself. It's attached to the hold down bracet.
http://67-72chevytrucks.com/vboard/s...d.php?t=454526
Guess I don't need it then (my truck has a TH350).
Thanks for the help! ![]()
Why would a TH400 kick down switch mount be in a K/20?
#15 |
Active Member
Cab swap?
#16 |
Nope, original cab.
#17 |
It can't be original to the K/20... someone must have added it. They didn't do a th400 4x4 version until like 76ish?
#18 |
well that makes sense why i cant get my kickdown switch to work on my 68 longhorn. its a 72 th400 and someone rigged the switch on the old carb.. it doesnt work with my new carb. learn something new every day
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
#19 |
I got the exact same one and was wondering what it was. Guess it goes in the pile of parts im taking to the scrap yard when im finally done cause i sure dont need it.
