Closed Thread
Old 08-07-2012, 04:24 PM   #4551
shawno72
C/10 junkie
shawno72's Avatar
Re: What did you do to your truck today!
Originally Posted by VDOG View Post
Do we all have that on our trucks, and if so where is it?
I have an extra charcoal canister off my 72 if you are in need of one. It is located underneath the passenger side battery tray.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 08-07-2012, 09:53 PM   #4552
VWNate1
VWNate1's Avatar
Post Re : Charcoal Cannister
Well ;
It's part of the SMOG equipments so maybe ~ some states still want it there .
If it's in good shape , and properly connected (takes at least three different hoses) it doesn't make the truck run badly atall .
I found the full A.I.R. pump , branch manifold & gulp valve for my '69's L6 and have been seriously considering installing it just because ...........
FWIW , A.I.R. pumps are bad for your exhaust valves but they're also dead simple to make look fine yet not harm anything .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-07-2012, 10:15 PM   #4553
69GWC
Getting the 69 ready to do a intake and carb swap, also going to install a new MSD streetfire HEI unit.
Going to a dual plane Holley intake and a 670 holley , new MSD plug wires as well.
69GWC is offline
Old 08-09-2012, 12:09 AM   #4554
VDOG
Grand PooBaa Member
VDOG's Avatar
Took one side of the 327 heads off to see if I need to hot tank them or just rebuild the engine. Of course as I was using my breaker bar to loosen the head bolts, I turn to far and slammed my finger into the 50lb intake manifold I have sitting near the engine. Dang it smarts to heck!! LOL
VDOG is offline
Old 08-09-2012, 12:14 AM   #4555
70CHEVYBB
70CHEVYBB's Avatar
installed a pitman arm and done an alignment before I left work. I do need to buya new door any suggestions ?????
70CHEVYBB is offline
Old 08-09-2012, 12:21 AM   #4556
Jarwood
Jarwood's Avatar
Finally put in rear shock relocators from ECE and all new KYB shocks. Will post pictures tomorrow. Got too late!
Jarwood is offline
Old 08-09-2012, 03:54 AM   #4557
jhaymon
jhaymon's Avatar
no. if you had it there will be a bracket on the core or you'll be able to see where it was(provided it hasn't been repainted)..i not sure what years it's on or if it was state to state. i normally only see them on the 72s only or truck that have had the tank moved out of the cab. i have seen a couple of 71s from cali, but it's either been removed on the years i've dealt with or wasn't there from factory.
is it done yet?
jhaymon is offline
Old 08-09-2012, 08:53 AM   #4558
67Slider
67Slider's Avatar
Went and visited her in paint prison. They should be shooting some primer on her in the next week or so. Body panels and floor repairs look good. shop took her down to base metal to start from there. Only a few more months to go!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 08-09-2012, 10:31 AM   #4559
asolde
asolde's Avatar
Originally Posted by asolde View Post
I put the charcoal canister back in, then a new battery tray. Put my hood hinges back on then my hood.
Adjusted my hood as close as I could to the specs in the assemblely manual.
asolde is offline
Old 08-09-2012, 01:50 PM   #4560
BlackedOut67shorty
BlackedOut67shorty's Avatar
I just washed mine and realize i have to repaint the bumper since the paints peeling off...
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline
Old 08-09-2012, 03:57 PM   #4561
Catch_22
Catch_22's Avatar
Can you post some more photos. You and I have very similar taste.
Mostly interested in your wheels. In process of moving from 20inch flat black wheels to 15 inch classic rally's I plan to blast and paint.
Catch_22 is offline
Old 08-10-2012, 12:55 AM   #4562
Delo69
Delo69's Avatar
Drove her down to the local weekly car show and met up with 70CST/10 to talk life and trucks..then grabbed dinner at Backyard Burger...yum.
_____________________________________
Dennis
1969 C10 250 w/3 on the tree - project/weekend warrior
2010 Subaru Impreza - daily driver
Delo69 is offline
Old 08-10-2012, 02:45 AM   #4563
oklalawnboy
oklalawnboy's Avatar
Stopped at MAR-K in Oklahoma City and bought all new mouldings for the 72. They are beautiful. I can't wait to get home and install them.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline
Old 08-10-2012, 05:08 PM   #4564
BlackedOut67shorty
Here some more pics, i used to have trim ring but someone stole them
Been actually thinkin aboot painting my valve covers black and polishing the fins and doing the same to my air cleaner
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-10-2012, 05:10 PM   #4565
BlackedOut67shorty
If you notice my mirrors are now square when the used to be circles.
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-10-2012, 10:13 PM   #4566
70CHEVYBB
70CHEVYBB's Avatar
I filled my gas tank for the first time, by the time I got back in my truck gas was running out of my sending unit. I pulled it out today and silver soldered it to stop the leak. Now I just have to get the gas smell out of the cab.
Old 08-10-2012, 10:18 PM   #4567
PAWS 72
PAWS 72's Avatar
Put some more go juice in and went to a local cruise inn.$48.00 to be exact.
PAWS 72 is offline
Old 08-11-2012, 12:49 AM   #4568
ole dollor
ole dollor's Avatar
well today i got to do some sanding...and more sanding....etc. etc. etc.....but one of these days....i hope i get ole dollar completely sanded down...
ole dollor is offline
Old 08-11-2012, 08:18 AM   #4569
GMC Canuck
I tightened the bolts that hold the steering rack to the frame.
A little bit every day, had the wheels off for over a month now. Maybe by September it will be rolling again.
GMC Canuck is offline
Old 08-11-2012, 12:43 PM   #4570
VDOG
Grand PooBaa Member
VDOG's Avatar
Found more fun facts about the 327 after tear down. WHEEEEEEEE!!!!!!!
VDOG is offline
Old 08-11-2012, 01:59 PM   #4571
terry b
terry b's Avatar
Look on the bright side the anti-freez looks fresh.
terry b is offline
Old 08-11-2012, 02:58 PM   #4572
VDOG
Grand PooBaa Member
VDOG's Avatar
True, and the oil looks great, so its a good chance this can be save. I guess.
VDOG is offline
Old 08-11-2012, 04:22 PM   #4573
50bomb
50bomb's Avatar
My 67 chevy c10 lwb has been a long 2 year project. So far we installed a 250/th350. 250 got new freeze plugs,intake&exaust gaskets,starter,flywheel,oilpan&valve cover gaskets,new oil line to Original gauges,Water temp to Origianl gauges, Th350 was rebuilt, 4 core radiator, 15x6 steelies, 69-70 automatic steering column/Cpp Linkage but kept my original 67 steering wheel on. We have the Original electrical but just patched up some wires. Next is hopefully a new Ignition coil and then I can move onto the brake work. Gonna keep that all drums for now. Someday disc brake up front.
Stovebolt-It is painted
50bomb is offline
Old 08-11-2012, 05:08 PM   #4574
VWNate1
VWNate1's Avatar
Post Re : Dead 327 V-ATE
That's fixable yes but since the cylinder has obviously been full of water for years , methinks it's time to simply get another engine core , they're cheap and plentiful here in La La Land (home to fruits , nuts & flakes) you'll prolly have to bore it to .030" before the rust pits are gone , not a good thing living here in The Desert .
Just to - day I went to Pick-A-Part on Blinn West of PCH in Long Beach and discovered SIX '67 ~ '72 C/10's & C/20's , several Customs , several rust free cabs , many dent & rust free fenders , inner fenders , core supports and so on..... all Long Bed Fleet Sides sadly .
I considered the 1970 C/20 cab for my '69 as it's rust free and has A/C....
I got a nice set of original green factory seat belts , mine are badly frayed and sun bleached to the point of me worrying if they're safe , now I'll be golden once I wash these out , dry and install them .
ALL these are V-8 rigs , PS , PB , AC etc. - it's all there .
-Nate
Geezer
VWNate1 is offline
Old 08-11-2012, 05:13 PM   #4575
Bennett68C10
Bennett68C10's Avatar
Installed my Billet Specialties Serpentine Conversion Kit and accessories
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Closed Thread
