fuel lines for 87 tbi truck
anyone know where I could get rubber formed lines fot a tbi 87 chevy I need the lines coming from the sending unit to the medal hoses on the frame of the truck I need formed ones cuz I bought straight ones and there pinching, any one know where to get those at?
Posted via Mobile Device |
Re: fuel lines for 87 tbi truck
I do not know were you can get them, but i would probably just get some metal lines, bend them and then use some hose clamps....
Are these the ones from the sender to the 6 port selctor valve(dual fuel tanks)? I have taken a look at fuel lines, and know that very little rubber lines were used ...Some hose pieces are only about 2 inches and some longer. .. |
Im not sure where to get formed lines but you should be able to use straight Fuel injection hose from the parts stores. if they are not lineing up enough to keep from kinking, you can losen the lock ring on the sending unit and just turn it till it does line up.
I'm having this same problem right now.....Help!
take a pic.... So we can see what actually is happening.
yeah ill turn the sending unit to make it work and its the lines off my tank that come up from sending unit an pump its 3 lines and its a single tank truck
