#101 |
Re: Maggie's Custom
obviously not your first rodeo, nice work
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#102 |
Re: Maggie's Custom
Thanks, I'm still learning, I notice the better I can see, the better my position, the better the weld! I just want all my stuff to look good all the time, I'm practicing as I go.
Not my first rodeo, but my first full on bag job! Thanks for all the comments!! Jason |
#103 |
Re: Maggie's Custom
Rear shock mount done!
Shock installed. Other side bag installed. Jason |
#104 |
Re: Maggie's Custom
Heres what I'm thinking for the front!
Moving the shock to the outside lower mounting point (going to reinfoce the mount) this gives the shock room to clear the brake tab and line, and move the upper mounting point the the top of the frame. Going to try and get this done tonight! Jason |
#105 |
Re: Maggie's Custom
I think im gonna copy ur idea for the front. Ive been lazy and still havent put shocks on the front of mine
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#106 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Maggie's Custom
You're doing impressive work.
If Maggie isn't impressed, you can say: 'Oh Maggie I couldn't have tried anymore...' Posted via Mobile Device
#107 |
Re: Maggie's Custom
lol! Shes heard it a million times!!
#108 | |
Rollin' Old Skool
Re: Maggie's Custom
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#109 |
Re: Maggie's Custom
hey is ur shock all the way extended in this pic?
#110 |
Re: Maggie's Custom
yes. I set it up to run a longer shock it need be. I put the shock at mid travel at ride height, but when I fully extended the shock it didn't look as if the suspension went that high. The shock has 6 1/2 inches of travel. I won't know how it works until the truck is on the road. I did the same on the front, I sent the shock and mid travel at ride height (the front shock has 5 inches of travel) I'll post pics soon!
Jason Last edited by jdoisher; 08-11-2012 at 10:20 AM. |
#111 |
Re: Maggie's Custom
Started working on front shock mount last night! Got one side done!
Started by cutting off the inside shock mount and making a template to reinforce the outter mount. Than cutting, fitting, and welding a 1/8 thick peice. more to come |
#112 |
Re: Maggie's Custom
For the upper mount I took a peice of 2x3 and cut it down until it fit the way I wanted.
#113 |
Re: Maggie's Custom
The rest!
Fully extended. Fully collasped. Mid travel. Bottom mount. Now I just have to do the same on the other side!! Jason and Maggie |
#114 | |
Re: Maggie's Custom
![]() i need to get off my lazy ass and go do that
#115 |
Re: Maggie's Custom
![]() I'll try again Last edited by jdoisher; 08-11-2012 at 05:34 PM. |
#116 |
Re: Maggie's Custom
Got the driver side done! I reused my template from the passanger side (just reversed it). I love this little plasma cutter!!
Put it in the bender! Than welded it in place. (sorry pic) |
#117 |
Re: Maggie's Custom
Made a template of the upper mount and traced it to the 2x3! Cut it out, and welded it into place!
Shock installed Top view. |
#118 |
Re: Maggie's Custom
cool truck you guys have. your really jammin right a long. keep up the good work.
#119 |
Re: Maggie's Custom
I srewed up all my picture posting as I was in a hurry!! Last night was Maggie's graduation ceremony!! (no not high school) She wanted to take her pictures with the truck but it not done. This is the best I could do, taken just as she was walking out the door!
We had a small party after and I took today off from the truck to hang out with her!! Jason |
#120 |
Registered Loser
Re: Maggie's Custom
Congrats Maggie!
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#121 |
chevy only
![]() Join Date: Sep 2006
Re: Maggie's Custom
whoa scared us for second congrats
CHEVY ONLY... Nothin Else ! |
#122 |
60-66 Nut
Re: Maggie's Custom
Yes, congrats to Maggie
![]() Don't blame you at all for spending time with her instead of working on the truck.
#123 |
high-Tech Red Neck
Re: Maggie's Custom
Great project. I will be looking forward to seeing how it turns out.
"He used to be a pretty nice feller, now he's a welder!" |
#124 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Maggie's Custom
Did moving the front shock outward cause any interference issues with your front tires at full lock?
Looks like it would have been easier to move the brake line tab? Your work and fab skills are great! Just wondering. Posted via Mobile Device
#125 | |
Re: Maggie's Custom
Thanks!! Jason |
