Old 08-10-2012, 11:07 PM   #1
Slammed 58 Chevy
Slammed 58 Chevy's Avatar
Mechanical question
Hello all.
I'm new here, and I mainly hang around the hot rod forums but have had a square body chevy since I was 15. And knew it was time to finally join this forum.
Dumb question, the main answer Im sure will be that I need a set of helping hands.
I recently did some motor maintenance on my 87 chevy 1/2 ton. This involved replacing all the belts while certain things were apart.
When tensioning the power steering pump I pried on the reservoir causing it too leak. So I now have a new pump and reservoir, pulley swapped and back in the truck. I see where there is a nub on the water pump and a notch in the power steering bracket. But its just not enough leverage for me to pry on and tighten the bolts. I think I barely get it, then as I tighten the bolts it pulls it down and puts slack in the belt.
I've tried a few different things and Im frustrated trying to do it myself. So I figured I would see if anyone has any tricks, or do I just need to wait till I get a friend to help me.
Thanks in advance.
Joey
Check it out! https://www.facebook.com/WoodysCustomsPA
Slammed 58 Chevy is offline   Reply With Quote
Old 08-10-2012, 11:39 PM   #2
GM-power
GM-power's Avatar
Re: Mechanical question
Its a whole lot easier with a extra set of hands.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
