Broken seat springs.
My bench seat has several broken springs on the driver side. It has great new vinyl on it so should I just find a new bottom for the bench and get it recovered in the original vinyl or attempt to repair it?
Re: Broken seat springs.
Since your vinyl is good you may want to get a good frame and transfer the vinyl over to it. It is not that difficult to remove the seat cover and reeinstall it onto a good frame.
Replacement springs were not available when I last looked for some. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I just asked an upholstery guy this today. I have 3 broken flat springs on my driver's side too, with everything else looking real good. He said it's nothing to pull off a few hog rings on that corner and replace the few springs, which can easily be gotten from Year One, where he orders them from.
Newbee
I have a complete bench seat that you can have, if you want it. Foam is shot, but I think the springs are fine.
![]() Join Date: Aug 2008
I would say replace the broken springs and go with what you have.
1969 Custom 30 wrecker
I recently recovered the seat in my wrecker project and found some broken springs on the driver side. I just went to the junkyard and found one that had a good passenger side and took the springs from it. That side rarely wears out and they swapped right in.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Are these them? http://www.diyupholsterysupply.com/s...y-springs.html Chris
The ones busted on mine are straight and flat, with a curly section at each end. I saw them shown in a pic in an older post referred to as the "main spring".
Dunenutt I think I will have to take your offer I could use that for some spare parts. The springs on the side are the ones are broken and the zig zag springs on the driver side are sagging the seat looks great but when you sit on it for a lil bit you can tell it is broken. It is really starting to bug me.
Posted via Mobile Device Last edited by mgkgmc; 08-11-2012 at 05:22 PM. |
#10 | |
Newbee
