![]() Join Date: Jan 2002
Push Lock fittings.
Is anybody using the push lock fittings or should I just stick with compression fittings. I know they are safer and less likely to leak, but cant seem to find all the fittings I need from one source. Is there a big problem with leakage with the push in fittings.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
Re: Push Lock fittings.
PTC work just fine, I ran them for 60,000 miles with no issues
push lock fittings have worked great for me. I have a ton of new fittings if you are interested. Just let me know what you need
