Old 10-06-2003, 01:53 PM   #1
HeavyK20
HeavyK20's Avatar
Aftermarket Springs?
This has probably been discussed a dozen times already but what brand of suspension do you recommend? All I have to go by is offroaddesign.com recommends Tuff Country. I am looking for a 4" lift with as soft of ride as I can get in a K20.
Thanks,
Eric
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 10-06-2003, 02:27 PM   #2
Mudder
Mudder's Avatar
I have used Tuff Country for a lot of years....I have the heavier springs but thats what I like.
Mudder is offline   Reply With Quote
Old 10-06-2003, 03:45 PM   #3
Dean
Dean's Avatar
I have used Skyjacker Softride on all of my K20s. I have found however that the ride is better in you don't use their nitro shocks. I used the regular skyjacker (hydro?) shocks on my last one and it rode better. It still doesn't ride like a Caddy....lol
Dean is offline   Reply With Quote
Old 10-06-2003, 05:52 PM   #4
Yukon Jack
Yukon Jack's Avatar
I'm pretty pleased with the 4" Tuff Country's I've been running. In the process of yanking them and putting in 6" Tuff Country's so you know I must be happy with Tuff Country's products. I am upgrading to better shocks though as I didn't like the Tuff Country shocks to well. Going with Rancho RS9000x's.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-07-2003, 05:05 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have the TC HD 2" springs and it's too stiff. As soon as I can I'm going to replace them with 6" ez ride springs from TC. Up front 1/2 or 3/4 ton springs are the same. In the rear, supposedly the TC springs help keep load carrying capacity of a 3/4 ton.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-07-2003, 11:40 PM   #6
Richard
I had read in an article a while back that the Tough Country springs had the lowest spring rate of all the mainstream manufactured "kits" this would mean a softer ride, but I think it would also lead to a bit more settling. The lower spring rate is also why a company that deals with rock crawling would recommend them. IMO nitro shocks are not a good choice with the older rigs. The leafs are shorter (less material to absorb the movement) and most do not have sliders. Shocks are 50% of the ride, sitck with a straight hydrolic shock like the RS5000 and the Tough Country's or another "soft ride" spring and you will be much happier with the outcome.
Richard
Old 10-08-2003, 09:30 AM   #7
HeavyK20
HeavyK20's Avatar
It sounds like everone agrees that hydraulic shocks are important.
Richard, what is a slider?
Eric
Old 10-08-2003, 10:37 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have the hydraulic shocks also, work great!
Old 10-08-2003, 05:48 PM   #9
HeavyK20
HeavyK20's Avatar
JIMs70GMC,
I just took a look at your truck. What tires are an it in the snow pictures? Is the 2" lift installed in those pics?
Eric
Old 10-08-2003, 10:07 PM   #10
Richard
If you look at the leaf packs on newer trucks and cars you will see a thin plastic piece inbetween the leafs at the ends. These help to reduce friction between the leafs making them more compliant. Leafs already have built in dampening because of the friction created by leaf movement. Coils do not have this and will generally require more dampening for the same given spring rate. Hope this helps explain.
Richard
Old 10-09-2003, 05:20 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
In the snow: stock springs w/ poly bushings up front. The tires are 325/60R15 BFG All Terrains on 15"x10" American Racing rims. The tires would rub when turning with any suspension flex.
