Old 08-09-2012, 03:08 PM   #1
byates2
byates2's Avatar
Right Stall converter??
I know you're supposed to base the stall convert off the CAM. Thats where my problem comes into play. I bought the engine used so i have no cam card or cam sticker, and i have no idea what cam it could be
I do know it is a Comp Cams. And there is a sticker on one valve cover with 10 part numbers and an executive order number(D-279-6)
It supposedly is a 383 stroker motor.
Ive narrowed it down to about 5 different cams it could possibly be
12-207-2 duration: 255/261 lift: .421/.451 050: 203/212
12-208-2 duration: 265/269 lift: .442/.465 050: 211/221
12-206-2 duration: 260/260 lift: .440/.440 050 212/212
12-210-2 duration: 268/268 lift: .454/.454 050: 218/218
Now this one has a higher lift, so if it was a stroker motor maybe this one?:
12-106-3 duration: 342/342 lift: .447/.447 050: 222/222
Any ideas??
How can find out what cam i have?
Are those numbers different enough to make much of difference in choosing stall converters
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 08-09-2012, 03:47 PM   #2
Fldawg
Fldawg's Avatar
Re: Right Stall converter??
i would probably not go over 3000 on the stall, my cam looks to be bigger than that and that's all i'm running and it works fine
Fldawg is offline   Reply With Quote
Old 08-09-2012, 05:57 PM   #3
kwmech
If it is a mildly built 383, my money is on the 210-2 cam (268) With 268 NOT being the lift, but the duration at .050.
Run a heavy duty stock convertor unless your going to romp on it all the time. What's the rear gear ratio?, tire size?
Old 08-09-2012, 06:16 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've got a very snotty cam in my SBC and the stall I have is 2,800.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-09-2012, 08:56 PM   #5
hugger6933
I would go on the side of caution and say 2400 to 2600. If you have a low rear gear lean more toward the 2600 side. If you do go with much over a stock stall and you drive in traffic a cooler at least and a cooler with a fan would be a good idea to keep the trans temp down. Also a deeper pan so you can have more fluid[more fluid=more cooling] and a trans temp gauge are not badideas either. Jim
hugger6933 is offline   Reply With Quote
Old 08-09-2012, 09:07 PM   #6
SS Tim
SS Tim's Avatar
Might just want to stop guessing. It is an unknown used engine. Pull the pan to look at the bottom end, oil pump and verify it is a stroker. Pull the timing gear to verify the cam numbers. Sticker could have come from anywhere.
SS Tim is offline   Reply With Quote
Old 08-09-2012, 09:14 PM   #7
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
going through this now with my converter, mine is being built or if you call TCI/B&M etc. the more info you can give them the better.
cam duration and lift @.50
truck weight
rear gear
tire size
engine hp @ flywheel
what are you doing with it, street/strip, towing. track etc.
A long time ago I R&R'd transmissions for a little while and asked the builders a ton of questions. The more info you can give them the better. I have seen plenty of overstalled converters kill the performance of a good engine.
I personally don't like to guess. I would verify what I could.
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 08-10-2012, 12:04 AM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
What are you using the rig for? Make sure you know what you are getting into if you are looking at a 3,000 stall on the street.
prostreetC-10 is offline   Reply With Quote
Old 08-10-2012, 10:43 AM   #9
GASoline71
GASoline71's Avatar
Yup... If you're towing and hauling... that 3,000 stall will make a lot of extra heat in the tranny.
Gary
Old 08-10-2012, 05:44 PM   #10
hayhauler71
hayhauler71's Avatar
I had a b&m stall that was crap it never impressed me than decided to have one built for my application and what a difference it made. MPC Midwest performance converter
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 08-10-2012, 07:20 PM   #11
atomic67
Junior Member
I run a 3000 stall behind my 383 with GM hot cam and 3.73 rearend. I have a Bowtie 700r4
And the combo works great. It is a Circle D converter.
atomic67 is offline   Reply With Quote
Old 08-10-2012, 07:30 PM   #12
Fldawg
Fldawg's Avatar
I stated before i'm running a 2800 small boss hogg converter with cooler and it works great with my 383 3:73 gear and a split duration lunati cam
specs are lift is 465/488 duration 290/300
Old 08-10-2012, 07:45 PM   #13
So.Cal.Super
It'll Buff Out!
Mine is being built also. I just posted those two because they are easy to call and talk to. I can't wait to see what it drives like
Man Card Rules
Old 08-11-2012, 10:46 PM   #14
byates2
byates2's Avatar
I dont want to race it or anything like that. I just basically want it to be a cruiser, i dont plan on towing much with it but i'd like to have the capability if need be.
I have pretty good size tires on 15x8 rims.
I believe the gear ratio is 4.11 but i eventually want to swap out the rear end with a ford and 3.73 gears unless the 4.11 are better for cruising and overdrive. I want to be able to have pretty decent take off capability but then again i'm not gonna be racing it.
Old 08-11-2012, 10:55 PM   #15
Fldawg
Fldawg's Avatar
With 4:11 or 3:73 you'll have plenty of take off with that 383, they are torque monsters
Old 08-12-2012, 12:16 AM   #16
turp mcspray
turp mcspray's Avatar
Any of the cams listed, will be mild in a 383. Your stock converter will work just fine.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-12-2012, 04:10 PM   #17
byates2
byates2's Avatar
What would be considered "stock" I had the old 2 speed power glide but now I'm converting it to a 700r4
Old 08-12-2012, 05:02 PM   #18
RRR18
RRR18's Avatar
Call ALL of the converter companys. They know better than anyone. Have ALL of your info and they will tell you what to run.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
