Old 08-13-2012, 05:12 PM   #1
scotts62
One day...
scotts62's Avatar
LS in 60-66?
Does anyone happen to have pics of how close their engine is to the firewall? I have to mod the firewall for more room for the AC but not sure how much room i will have, i know it kind of depends ultimately where i put the engine and trans mounts but just need an idea. Im putting a 5.3 in my 62.
Thanks, Scott
Scott
93 crew cab build
Project 62
Old 08-13-2012, 05:27 PM   #2
hardhead
Re: LS in 60-66?
PM me your e-mail and I will have my son send some pic's from his phone. I would post them on here but I'm not to computer savvy. We are finishing up a 66 with a 6.0.
hardhead is offline   Reply With Quote
Old 08-13-2012, 10:31 PM   #3
TR65
TR65's Avatar
Re: LS in 60-66?
Here is a 6.0 in my 65.
The back of the truck intake is 3-1/2" from the firewall. the passenger side coil is as far back as it can go without hitting the stock firewall. If the coils were relocated it could go further back. The engine is 1" forward of the original 283 mounting position based on the front face of the block.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-13-2012, 10:40 PM   #4
scotts62
One day...
scotts62's Avatar
Re: LS in 60-66?
Ah ok, thanks for the pic.
I got the HVAC box out of the '05 also and am trying to make my mind up if i want to rework the firewall and make it work or if there will be enough room to even do it. It would be cool to keep what i can and do it but not sure yet.
Scott
93 crew cab build
Project 62
Old 08-13-2012, 10:47 PM   #5
rmvlt1100
rmvlt1100's Avatar
Re: LS in 60-66?
Here is mine. I dont have AC in mine. I used Hooker Header adapters for mine and put it as far back as the adapters would let me.
Here is a picture of the adapters.
Good luck with the build.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 08-13-2012, 10:53 PM   #6
scotts62
One day...
scotts62's Avatar
Re: LS in 60-66?
Nice, i have the CPP perches just need the adapters. Im getting close to putting engine in for mock up so i can make mounts and finish the frame.
Scott
93 crew cab build
Project 62
Old 08-13-2012, 10:59 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS in 60-66?
first ones an old pic
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-17-2012, 10:11 PM   #8
scotts62
One day...
scotts62's Avatar
Re: LS in 60-66?
Well im working on putting mine in but i dont think that the stock exhaust manifolds are going to work because they are hitting the frame.. I have to o raise the engine up higher that you guys probably did since its going to lay out and the oil pan is the first to hit
Scott
93 crew cab build
Project 62
Old 08-18-2012, 09:56 PM   #9
TR65
TR65's Avatar
Re: LS in 60-66?
Scott,
The Trailblazer SS or SSR stock manifolds will fit in the frame. They hug the block closer.
TR
1965 C10 SWB Fleet
Two owner
Old 08-18-2012, 10:07 PM   #10
scotts62
One day...
scotts62's Avatar
Re: LS in 60-66?
Sorry i accidently clicked edit on your post instead of the quote
Awesome, thanks for the heads up, any particular place to look?
Will they tuck in closer than this?
Scott
93 crew cab build
Project 62
Old 08-19-2012, 09:39 AM   #11
Clyde65
Clyde65's Avatar
Re: LS in 60-66?
I used csls1 headers from sanderson. They are shorties and tuck real nice, look nice and sound nice.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-19-2012, 03:12 PM   #12
TR65
TR65's Avatar
Re: LS in 60-66?
Scott,
The stock manifolds mentioned above cleared my 65 frame without modification. There was a thread here somewhere that said they are not very expensive straight from GM. They are good manifolds by the way, used on the high HP 6.0 engines.
TR
1965 C10 SWB Fleet
Two owner
Old 08-19-2012, 04:46 PM   #13
scotts62
One day...
scotts62's Avatar
Re: LS in 60-66?
Oh ok, i looked a bit on evilbay to see if someone may have a used set for sale but didnt come up with much. Found one for sale but they wanted $150 for it.. hope i can find some cheaper if not ill get the sandersons Clyde65 mentioned above i guess, they were not bad for headers.
Scott
93 crew cab build
Project 62
Old 08-19-2012, 05:00 PM   #14
not2oldchevy
Re: LS in 60-66?
Look at some for a 2006 GTO they fit close and look good. I have a pair if you can't find any .
not2oldchevy is offline   Reply With Quote
Old 08-19-2012, 08:08 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS in 60-66?
you can find tbss headers on performancetrucks and ls1tech occasionally, but I've actually had good luck finding them on CL, don't search to "TBSS" or "headers" tho.
Try using searchtempest to look through all the CL in your area, search for things like "ls1, ls2, ls3, lsx, gto" and you seem to get better hits without random hondumb parts.
Old 08-20-2012, 06:39 PM   #16
scotts62
One day...
scotts62's Avatar
Re: LS in 60-66?
Been looking around, not any close but you never know what will come up on CL.
Scott
93 crew cab build
Project 62
Old 10-12-2012, 01:29 PM   #17
mlevario99
Re: LS in 60-66?
Sorry to hijack this thread, but I am looking also for headers. I am using the Hooker Header adapters and the CPP perches on my 66 truck and I order the CSLS1 Sanderson Headers from Summit Racing, the problem is that is about a month that I order them and the date keeps changing, I had the 10/13 to be shipped, then yesterday I got another card that now is 10/23. What other headers can I use with my setup.
Thanks for your help
mlevario99 is offline   Reply With Quote
Old 10-14-2012, 10:49 AM   #18
bryankichler
bryankichler's Avatar
Re: LS in 60-66?
mine is about 3 1/2 - 4" from the firewall might be able to find pictures in my build thread
bryankichler is offline   Reply With Quote
Old 10-15-2012, 09:16 AM   #19
Clyde65
Clyde65's Avatar
Re: LS in 60-66?
I would suggest you call Sanderson directly, that is how I got mine. If they have a different vendor that has a set, maybe you can buy from that one.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-15-2012, 09:38 AM   #20
mlevario99
Re: LS in 60-66?
Thanks Clyde65, I will do that.
Old 10-15-2012, 01:59 PM   #21
bryankichler
Re: LS in 60-66?
I have the header problem also. I went with a set of fbody headers off eBay and made some modifications to them and my frame just to find the drivers side hits my lower A arm. I don't want to lop off a chunk of my A arm to clear and i don't think I can modify the header to make it work. I don't recommend fbody headers for a 66 this may also depend on distance from firewall and if you raised the engine.
Old 12-15-2021, 08:30 PM   #22
65ChevyUtah
Re: LS in 60-66?
Can you tell me what Cold Air intake you used ?
Thanks.
65ChevyUtah is offline   Reply With Quote
