Old 10-07-2003, 08:03 AM   #1
TIMSPEED
TIMSPEED's Avatar
Another Cab Mount Question; How many are there?
Are there only two cab mounts? (One on each side; outside the framerail, just under the doors.) My gf's dad said it's EASY to replace cab mounts, and from the looks of it, there's only two!
But I think I remember someone saying, each side has two bushings...an upper and a lower. Is this correct?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 10-07-2003, 08:07 AM   #2
bigblock73
yeller
bigblock73's Avatar
There are four, two in front and two in the rear...I believe there are a total of eight bushings (2 for each mount) though.
-Jeff
bigblock73 is offline   Reply With Quote
Old 10-07-2003, 08:14 AM   #3
TIMSPEED
TIMSPEED's Avatar
Where are the other two? Under the radiator??
See Them Here
Old 10-07-2003, 08:25 AM   #4
bigblock73
yeller
bigblock73's Avatar
the two in front are right about where your feet rest (one on the left, the other on the right), and the two in the rear are at the very back of the cab (in the same location as the front).
Crawl under and have a peek...the bolts bolt from under the cab and thread into the cab thru the bushings.
-Jeff
Old 10-07-2003, 08:32 AM   #5
TIMSPEED
TIMSPEED's Avatar
Hmm ok..hopefully this fix my CRAPPY ride, as well as my leaning problem.
But then I'll have a new problem..I'll have to drop the front another inch or so
See Them Here
Old 10-07-2003, 09:50 AM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Actually, the 2 rear ones are on the inside of the framerail whereas the front is on the outside of the framerail.
here is a pic from the front. The first set outiside the framerail and in front of the crossmemeber is the core support, the second set outside framerail and behind the crossmember is the front cab mount, and the one in front of the rear crossmember and inside the framerail is the rear cab mount.
If you are replacing the cab bushings, you need to replace the core support bushings. Unless you replace them with rubber, you ride quality will be STIFFER.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-07-2003, 05:26 PM   #7
Low87on20s
Live from Atlanta
Low87on20s's Avatar
not to hi-jack a thread, but how much (in inches) would bad/failing cab mounts cause a truck to lean?
Paul
Low87on20s is offline   Reply With Quote
Old 10-07-2003, 05:47 PM   #8
Captkaos
Captkaos's Avatar
No more than about 1/2" I would say (PICKUPs). Typically the top bushing is about 3/4" tall, and it has a 1/4" Washer/support cup holding it on the later models.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-07-2003, 05:53 PM   #9
TIMSPEED
TIMSPEED's Avatar
Ehh..I think mine's actually leaning about 3/4"...I'll let yall know after I replace my bushings...
See Them Here
Old 10-07-2003, 05:57 PM   #10
TIMSPEED
TIMSPEED's Avatar
So the mounts are only located, where the arrows are pointing, right?
See Them Here
Old 10-07-2003, 06:01 PM   #11
Low87on20s
Live from Atlanta
Low87on20s's Avatar
Hey TIMSPEED, is your truck leaning on the passenger side or the driver side? I guess if it was both, you either couldn't tell or wouldn't care unless the ride was just that bad?
Paul
Old 10-07-2003, 06:09 PM   #12
bigblock73
yeller
bigblock73's Avatar
No, the very front ones are the core support mounts. Look at mine, you can see the front ones right behind the engine (outside of frame), and the rear ones are further back inside the frame.
Hope this helps.
BTW - Chris, your rear mounts look waaaaay too far back in the pic...do you have a limo or something?? Just kiddin, probabally just the way the photo turned out.
-Jeff
Old 10-07-2003, 06:15 PM   #13
Low87on20s
Live from Atlanta
Low87on20s's Avatar
-Jeff
I was thinking it was a frame for a crew-cab short bed.
Paul
Old 10-07-2003, 06:22 PM   #14
TIMSPEED
TIMSPEED's Avatar
Well, I went out and snapped a picture of my cab mounts (directly under the sides of the cab) Here's what they look like...
Is there any EASY way to get to the rear cab mounts, without taking the bed off??
Also, (last question, I promise) I just take out this big bolt going through the bushing, then jack up the cab, and slide out the old bushings and in the new, right?
See Them Here
Old 10-07-2003, 06:26 PM   #15
bigblock73
yeller
bigblock73's Avatar
You shouldn't need to touch the bed, the mounts are directly below the rear of the cab.
Yes, remove the bolt, jack up the cab a little, remove the old mounts. The bolts might be stubborn, lots of weight, stress, and years on them.
BTW - your bushings don't look too bad.
-Jeff
Old 10-07-2003, 06:32 PM   #16
1FaastC10
1FaastC10's Avatar
Jeff, you have to consider that those are the lower bushings he's showing, so they're not bearing any weight. i bet the top ones are smooshed to hell.
1FaastC10 is offline   Reply With Quote
Old 10-07-2003, 09:56 PM   #17
BaggedC10
Under construction!
BaggedC10's Avatar
TIMSPEED, bring your truck up to my place and I'll replace them. I'm installing PST ones on my truck because otherwise, they'll just sit in the box. You can also get your leaf springs.....for free.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 10-07-2003, 10:38 PM   #18
TIMSPEED
TIMSPEED's Avatar
DAMN! I'M THERE!
See Them Here
Old 10-07-2003, 10:47 PM   #19
BaggedC10
Under construction!
BaggedC10's Avatar
DAMN! I'M THERE!
I am being serious too. PM me if you are interested in doing that.
Old 10-08-2003, 02:42 PM   #20
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I want pictures removal and instaltion I will need to do this also sooner or later!!
Do you think we should start some tech articles? On things like this?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
