Old 07-16-2012, 11:26 PM   #1
kurk4fun
kurk4fun's Avatar
72 c-30 manual to power steering
Hey guys! I have a 1972 chevy c-30 and want to convert the manual steering to power steering. I've found a 1979 c-20 p/s gear and pump. Will I need to change the pitman arm? If I need to change it what arm should I use ? Tks
kurk4fun is offline   Reply With Quote
Old 07-18-2012, 07:37 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 72 c-30 manual to power steering
Welcome to the board.
Can anyone help?
Keith
Convert to disc brakes.
Old 07-18-2012, 11:50 AM   #3
SCOTI
SCOTI's Avatar
From what I remember, the pitman arm is different on a manual vs pwr steer C10 so it would suggest they're different.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-23-2012, 09:25 AM   #4
Copperman
Copperman's Avatar
Usually. I am only familiar with the C10 but there is a Pitman arm that is power steering only. The receiving splines are larger. You might have to change out your rag joint as well. In the C10 the input splines on the PS gear box are larger in diameter and the old rag joint will not fit.
Matt
1970 C10
Copperman is offline   Reply With Quote
Old 08-13-2012, 09:27 PM   #5
kurk4fun
kurk4fun's Avatar
Thanks to everyone who responded to my power steering question. I did have to find a different pit-man arm and a new rag-joint. the splines on a 1972 steering gear are more course than the fine course on a 1979. I almost have everything together, still waiting on my mounting bracket for the pump .
