Old 08-14-2012, 08:09 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Airline Routing
What is the best routing for the airline from the front bags. I have a couple of pushin bulkhead fittings that i could use through the crossmember but that is just more places to leak. I have never seen a compresion type bulkhead fitting.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-14-2012, 11:22 AM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Airline Routing
I just drilled through the crossmember's spring pocket towards the rear and used a 90 PTC on the bag. Shoved a thick rubber grommet in there and called it good. For some added comfort, you can slide a piece of rubber hose over the air line where it goes through the hole. After that, it just runs down the frame rails.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 08-14-2012, 11:36 AM   #3
ERASER5
ERASER5's Avatar
Re: Airline Routing
They make them every day.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-14-2012, 01:19 PM   #4
Pro Performance
Pro Performance's Avatar
Re: Airline Routing
x2
Pro Performance is offline   Reply With Quote
