Old 10-07-2003, 08:47 PM   #1
lotik
drag it like you stole it
removing key cylinder..
i have a tilt van column in my truck, and it has the key cylinder on the column. is there a way to remove it? i already have a cylinder mounted in the dash i am using.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 10-07-2003, 09:09 PM   #2
Blue Beard
Blue Beard's Avatar
If you are just trying to remove the cylinder from the column.........there is a retaining keeper inside the column.
I would say that the outer collar might have to be reworked to get it smooth.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-07-2003, 10:44 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I bet someone on the 73-87 board will know, that series of truck has the ignition cylinder in the column.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-08-2003, 02:40 AM   #4
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
You have to pull the wheel and retaining plate. There is a small "c" clip that holds it in. Then remove the turn signal switch. After that, there is a small set screw that holds the cylinder in place. Remove that, and pull out the cylinder. On some models it is not necessary to remove the t/s switch. Good luck. If ya need pics, let me know.
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 10-08-2003, 05:20 PM   #5
lotik
thanks fellas
