06-01-2012, 01:40 PM | #51 |
Re: SANFORD build thread
Thanks guys,lolife99 it is to the driver side,I did not center the r&p housing,the rack It has a 2 1/2 turn lock to lock,I centered it between left and right and tried to center the outer tie rod swivel which is under the boot,however I did manage to get it to the driver side about a 1/2 to far,I know It should be exactly centered but I am going to check the bumpsteer when I do the alignment,if things do not work out Speedway motors has a set of offset mounting bushings that I will use to move it.Time will tell but honestly for a cruiser I dont think I will notice any difference except maybe turning radius.Hope this makes sense.Thanks for looking guys.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
06-01-2012, 10:25 PM | #52 |
Nice fab work, wheels and tires are killer. perfect stance.
----------------------------------------------- "I wanna be like Dino when I grow up" |
06-08-2012, 01:41 AM | #53 |
chevy only
bump
CHEVY ONLY... Nothin Else ! |
06-08-2012, 02:02 AM | #54 |
Nice build. Sanford is looking good!
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
06-08-2012, 04:22 PM | #55 |
update,I have just about everything finished in the rear,I was able to set my pinion angle and then I installed my lower bag mounts.I had to move the upper bag mounts in order to get the truck to sit where I wanted it to.I also braced everything up pretty good because I will be doing a little bit of towing with this thing,I got the shocks mounted as well.I am pretty much finished with the fabrication on the rear suspension just a little bit of final welding when I strip it down to paint it.I also re-purposed the factory bump stops so if it does bottom out it hopefully will not damage anything.
06-08-2012, 04:27 PM | #56 |
I also have most everything for the exhaust,I got a spare set of headers on the cheap that I will cut up and use to modify the ones I will use.well that is it for now. Thanks for looking
06-08-2012, 04:39 PM | #57 |
chevy only
one of my favorite builds going on, such nice work on the rear
06-15-2012, 07:10 PM | #58 |
subscribed
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
06-16-2012, 09:20 PM | #59 |
Just a small update,I have been working on some loose ends and one of those was getting the steering shaft made which in itself was not that hard however modifying the motor mount was a major PIA.I spent most of today doing that and re-enforcing the mounting tab on the trans mount.I also shortened my drive shaft so I will send it out to have balanced.I still have to make the upper shock mounts and then on to the exhaust.
06-16-2012, 09:30 PM | #60 |
this is what the shaft looks like and the motor mount mods complete,in some of my previous posts it was pointed out that my rack wasnt centered in the frame,I knew it was to the drivers side a little but after checking it with the crossmember in the frame rail it was off more than I thought so I cut it out and re-positioned it,so this was a screw up on my part but now is the time to fix it.That is how it goes sometimes and thanks for pointing that out.Thanks guys for looking.
07-22-2012, 07:59 PM | #61 |
not a lot to update,but I did finish modifying the headers and making the exhaust,I forgot to take a pic before I removed it from the truck
07-22-2012, 08:01 PM | #62 |
07-22-2012, 11:21 PM | #63 |
chevy only
such nice work,killer job
08-05-2012, 11:46 PM | #64 |
Dang i havent checked up on this in a while!!! Killer fab work man!!! Keep it up its looking great
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
08-14-2012, 07:43 PM | #65 |
Just a small update.I am just about done with all the heavy fabrication,I still have a few things like front shock mounts,front sway bar ,trans linkage and so on.I still have to finish modifying the trailing arm crossmember and get the rear brake assemblies on and route the parking cables.I will blow this thing in the near future and paint the chassis and other components etc.thanks for looking.Thought I would trow a few pics of it together one last time before paint.
08-14-2012, 07:45 PM | #66 |
few more
08-14-2012, 11:22 PM | #67 |
VA72C10
Nice work! So...no issues with clearance with the exhaust at the notches?
Looking for a 67-72 swb or blazer project in or around VA. |
08-14-2012, 11:39 PM | #68 |
Just here to tinker
Hol-y man. This is coming out super awesome. Looking forward to some paint shots. Inspiring build thread!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
08-14-2012, 11:54 PM | #69 |
chevy only
always such nice work!
08-15-2012, 05:56 AM | #70 |
looks well laid out and tidy.nice job.
08-15-2012, 08:11 AM | #71 |
Thanks guys,VA72C10 it does appear it is hitting,but it is not.also this is at full drop and there is at the closest point about 3/8 clearance so I dont think there will be any problems.I have had this thing together and apart about 3 or 4 times to check for any unforseen problems.Hopefully this is the last time as I am about to lose a little steam on this project.Wife and I have made reservations for power tour next June so I better get on the ball.Thaks again.
08-17-2012, 09:24 AM | #72 |
Dig your work !
Hey, how exactly is a rainbow made? How exactly does the sun set? How exactly does the posi-trac rear end on a Plymouth work? It just does. |
09-03-2012, 04:14 PM | #73 |
got the engine ready to go in,currently cleaning and painting trans and other driveline components,will update
09-03-2012, 11:44 PM | #74 |
chevy only
nice & clean
09-04-2012, 09:18 AM | #75 |
Damn..that motor color looks like a Jolly Rancher candy..makes you wanna lick it..wow did I say that!.. nice job
