5" drop rear
I just ordered some CPP 5" drop rear springs and shocks for my 65 . Please post up some 5" drop rear pics.
Re: 5" drop rear
i just did this drop. you will also need a trac bar. no pics yet.
'66 chevy lwb c10 '65 chevy lwb c20 |
Re: 5" drop rear
Here's my 3/5 drop
'66 "Wrong bed" (Long stepper) 350, 4-speed '66 Shortbed Stepside, 350/TH350 www.instagram.com/d_ray_pinstriping |
Re: 5" drop rear
Did you order the shock relocator kit also? If not you're going to be unhappy with the ride. The shocks are at an extreme angle and won't work worth a flip. Speaking from experience!! If I were you i would cancel my order of the shocks and get the No Limit Shock relocator and shocks. It rides 100 % better. If you like the 5" drop look but want a good ride, change the springs to 3" drop and get 1 1/2"-2" blocks. I have attached a picture of mine done this way. It is a picture at my daughters wedding but you can see the drop.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain Last edited by 65Gregg; 06-08-2012 at 12:11 PM. Reason: I can't spell |
SIR
Re: 5" drop rear
here ya go....
66long low fleet http://community.webshots.com/user/LVNR66 |
![]() Join Date: Jul 2009
Re: 5" drop rear
This is a 4/5 drop......
![]() Join Date: Mar 2012
Re: 5" drop rear
Here are a couple of mine. just installed 2 1/2 drop spindles and rear bags. Before and after
Re: 5" drop rear
Nice!
Sir, what's the front drop? I have a GMC long fleet (leaf springs) and just have Early Classic drop shackles in now (2"). I want to go with their lowering springs, which I think is a 4 1/2" drop. I have 2 1/2" drop spindles up front. Hope it comes out looking like yours.... |
Re: 5" drop rear
All I did in front is 2 1/2 drop spindles and stayed with original coils which were in the truck with the six cylinder and I have a small block in there now so probably another inch of drop with weight difference not really sure
Re: 5" drop rear
ive got a cpp kit (shock relocater, adjustable track bar 4 " springs and 1'1/2 blocks)
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
Re: 5" drop rear
![]() Join Date: Mar 2010
Re: 5" drop rear
Heres mine with 2 inch spndles. 3 inch drop springs in the front
3 inch drop springs in the rear with 3 inch blocks. 5 inch drop springs in the rear won't be much of a ride. good luck
65 burb On the road Mar 26th Finally |
Re: 5" drop rear
I'm about to put the lowered springs, shocks and track bar in the rear, any tips and or tricks to smooth out the install would be great.
#14 | |
Re: 5" drop rear
Posted via Mobile Device |
#15 |
Re: 5" drop rear
With 2 in blocks and c notch
![]() ![]() Posted via Mobile Device |
