front spring cutting question
I have 2 1/2 drop spindles and I just bought some Belltech 2" lowering springs, but I would like another 1-1.5 inches lower. Does anyone recommend cutting the brand new springs or is there another way to achieve it?
1962 C-10
Re: front spring cutting question
I would check and make sure that the springs are seated and settled properly. I've had issues in the past where the spring didn't sit in the lower or lower cup properly. If it looks okay, I've cut new springs before. It hurts a little cutting into a new part, but you gotta do what you gotta do. Good luck... jc
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
will cutting them affect the ride comfort?
Have you tried them on yet. Sometimes it takes a while for them to settle. You wouldn't want to cut them to find out later that it is two low when they settle. 6" is vary low watch out for speed bumps and make sure your front wheels will fit.
they are on in the picture. it sat nice with 15" wheels, but with the 20's, i would like to get a bit lower
cut it
Cut your stock springs down if you don't want to cut your new drop springs.
I cut the the drop springs on my blazer, I am running 2-1/2" drop spindles with 2" drop springs and I cut off one coil. I am happy with the ride.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
![]() Join Date: Jun 2006
Is the motor in it? If its not you better wait until it is. When I cut my springs I cut one loop from each end rather than both from one end, but that was on my ElCo. I haven't pulled apart my front end yet to find out.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
yes the motor is in. I think i'll take the advice and drive it for a week and then decide whether to cut a loop out of them like YBNORML said.
![]() Join Date: Nov 2010
cut them!!
I would cut 1/2 loop at a time
#15 |
"Where were you in '62?"
![]() Join Date: Jul 2004
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#16 |
Charlie Daniels w/ a Tq Wrench
As mentioned, drive it for a couple weeks, see if it settles any, as they usually do just a bit. Then cut if it still isn't low enough. The spring rate will increase resulting in a stiffer ride, but sometimes a higher spring rate is desirable on a lowered vehicle since you are working with less travel after all.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
