Old 04-17-2012, 09:17 PM   #201
mjensen
mjensen's Avatar
Re: 72 K20 Cab Body & Paint Complete!
That turned out awesome! I love it!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-17-2012, 09:20 PM   #202
72KAY20
72KAY20's Avatar
Thanks Mjensen!
72Kay20 Bel Air, MD
1972 Hugger Orange K20 LWB
350, 4wd, 4spd Sm465, Dana 44, HO52
Other Toys
69 Cortez Silver Z28
86 White Buick T Type
72KAY20 is offline   Reply With Quote
Old 04-17-2012, 09:23 PM   #203
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Absolutely awesome! Our trucks should look/set pretty close. Nice job on the whole thing!
Ryan
1969 Chevy milk truck
Old 05-01-2012, 09:09 PM   #204
72KAY20
72KAY20's Avatar
Have been driving my truck more and have noticed that the driver's side leaf spring shackle sometimes hits the shackle stop on bumpy roads. Pretty loud bang at times. Took the shackle stop off and problem went away. It should not be a problem from what I have read on other posts.
Was wondering what opinions others have on that shackle stop?
72Kay20 Bel Air, MD
Other Toys
Old 05-01-2012, 10:06 PM   #205
ryanroo
ryanroo's Avatar
is that a 2.5" or 4" lift? the truck is amazing. i cant wait to drive mine
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-01-2012, 10:22 PM   #206
Low Elco
Looks great, just great. How wide are the rims? Being a 3/4 ton, some of those factory 16x10's would look AWESOME on that truck. Or Polished Alum. slots! (but I'm partial) Looks great as-is!
Low Elco is offline   Reply With Quote
Old 05-02-2012, 05:35 AM   #207
72KAY20
72KAY20's Avatar
Thanks. It is suppose to be a 2.5" Tuff Country lift kit.
Rims are just the factory size, maybe 7.25 or 8". Would love to find some wider steel factory wheels and mount some bigger tires. I like the look of the trim ring with the factory hub caps with the logo. Mounted the biggest that was recommended. Was told I could go with a bigger tire but would probably wear the centers out prematurely because of the way the tire was being pulled in to a narrower wheel.
Anybody know a source for wider factory 8 lug wheels?
72Kay20 Bel Air, MD
Other Toys
Old 05-02-2012, 06:34 AM   #208
Low Elco
I think there's a thread of 3/4 ton pics here where there's a good bit of info about the big wheels. Also could have yours widened. I like the modern caps. Still an awesome truck!
Old 05-03-2012, 09:16 PM   #209
72KAY20
72KAY20's Avatar
Went to the annual spring Carlisle Car Event last week and picked up a pair of Vintage 1971 Farm Truck Tags. Thought they would look pretty cool on the K20. Was able to get the vintage tags approved by the MD MVA this week so I bolted them on this afternoon. Can keep them on it all the time now.
They are actually cross-referenced now in the MVA database with my other plates. The only down side is that every 2 years I have to pay to register both sets of plates. Oh well, worth it to me.
72Kay20 Bel Air, MD
Other Toys
Old 05-04-2012, 02:01 AM   #210
shanboo71
Originally Posted by 72KAY20 View Post
More pictures of progress after sandblasting frame.
Nice! and thanks for sharing. Im about two weeks away before i start pulling my 71 k20 apart. cant wait!
shanboo71 is offline   Reply With Quote
Old 05-04-2012, 02:26 AM   #211
Dieselwrencher
Cool deal on the plates!
Ryan
Old 05-04-2012, 10:00 AM   #212
ryanmctee
ryanmctee's Avatar
Wow, everything turned out great. Congrats on finishing such a big project. And a big thanks for so much posting on the build process. I've used your thread several times for reference on my build, which is getting closer! Enjoy your truck - Ryan
Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=512620
ryanmctee is offline   Reply With Quote
Old 05-04-2012, 03:14 PM   #213
litew8
litew8's Avatar
those plates
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 07-23-2012, 08:24 PM   #214
72KAY20
72KAY20's Avatar
The K20 has been running great. Here are some pictures of the hidden receiver behind the front bumper. Really like the way it looks and works. I installed some Tweco twist connectors for the 12 volt cables for my winch. They are sweet!!! Just push together and twist and you have a solid electrical connection.
Still need to get a nice class 4 or 5 hitch for the rear. I want to be able to pull my 10,000 lb car trailer. Anybody have any suggestions? Reese, Curt Mfg, others? Most available by web order are only class 3.
72Kay20 Bel Air, MD
Other Toys
Old 08-07-2012, 10:37 AM   #215
72KAY20
72KAY20's Avatar
Located a Class 5 hitch by Curt Mfg on the web that looked like it would work. 15,000 lb pull rating - definitely more heavy duty than I think I will ever need.
It has a 5.5" drop below the rear frame rails. My other choice from them had about a 7' drop which I thought would be too much. Did not want to impact ground clearance.
Started to fit up the side supports and then realized my rear mount tank and dual exhaust hangers were in the way. Went to Plan B - Customize.
Will need to do some welding and add some more metal but it will be plenty strong in the end. At least enough to pull our 10,000 lb rated car trailer.
72Kay20 Bel Air, MD
Other Toys
Old 08-07-2012, 10:44 AM   #216
killer71
killer71's Avatar
Beautiful truck!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 08-07-2012, 11:12 AM   #217
Low Elco
Still awesome. I sent my radio off to your guy yesterday. It'll look good in my uncut dash. Get that truck to workin'!
Old 08-08-2012, 07:55 AM   #218
72KAY20
72KAY20's Avatar
Thank's killer71 and Low Elco.
Pretty sure you will be very happy with your customized stealth radio Low Elco. I have surprised quite a few passengers when I turn on the old AM radio and crank up the watts.
Although I don't listen to the music cranked up like I did years ago, will still turn up a few every now and then and feel the 12" subwoofer shake the bench seat.
72Kay20 Bel Air, MD
Other Toys
Old 08-12-2012, 08:38 PM   #219
72KAY20
72KAY20's Avatar
Here's a side view picture with the bumper mounted with the hitch installed. Ended up raising my chrome step bumper a little so I could get the class 5 hitch to fit underneath better. Actually am happier with the way it looks now compared to before when there was a larger space between the bottom of my tailgate and the top of the bumper.
Also happy with the ground clearance with the hitch installed. Glad I did not choose the other hitch from Curt Mfg. that would have been about 2" lower.
72Kay20 Bel Air, MD
Other Toys
Old 08-13-2012, 01:00 AM   #220
Dieselwrencher
That looks perfect!
Ryan
Old 08-13-2012, 07:34 AM   #221
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man that truck turned out nice, I have always love the K20's my first truck was a 71 K 20.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 08-13-2012, 08:38 AM   #222
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I hope my K20 turns out half as good!!
Old 08-14-2012, 08:16 PM   #223
72KAY20
72KAY20's Avatar
Appreciate the kind words Dieselwrencher, MrBeast, and DeadheadNM! Like the progress you guys are making on your trucks.
Still tinkering with a few final projects on the K20 besides the class 5 hitch.
Not completely happy with my fuel fill tube. It works but does not flow very fast. Open to suggestions.
Bill is repainting the cowl vent piece between the hood and the windshield. The paint wrinkled up in 3 places on the cowl. Around 2 edges and where the antenna is mounted. That is the only area on the truck that had the problem. Can't wait to get it back on the truck.
Bought some 1x6x10' fresh cut rough oak boards for the side racks. Planning on making 4 board racks for both sides and front of bed once they dry out. Currently air drying them in my garage. Have borrowed a friend's planer to smooth them out. Will start on them one of these weekends. My goal is to have them complete by the 1st week of October. May put them on when I take it to the Ocean City, MD Endless Summer classic car cruise.
72Kay20 Bel Air, MD
Other Toys
Old 08-15-2012, 10:39 AM   #224
ryanmctee
ryanmctee's Avatar
Regarding your fuel filler, this is what I did and I'm very happy with it. The fill rate is really good, and it's a clean looking set-up, at least that's what I think. Get a 67-72 Blazer fill tube and cover (I got mine used from a board member, just do a search for them) and mount it inside your bed. All that is required is using a hole saw in the very bottom corner of the bed for the filler hose.
Here's a couple of pictures of how mine turned out. If you'd like some more, just let me know. Again, I am VERY happy with how fast my tank fills, and the look of the filler. Ryan
Old 08-15-2012, 09:27 PM   #225
72KAY20
72KAY20's Avatar
Nice job on that fuel fill Ryan. I like that much better than the ones I've seen in the floor of the bed. Thanks for posting the pictures. Would like to see how you routed the fuel and vent hose under the bed.
I mounted my tank with the fuel fill inlet towards the passenger side, can't remember why. I think because the fuel fill on the tank could be filled easier from inside the passenger side rear wheel well. Oh well it works but I just can't fill the tank at full speed or else the auto-shut off feature keeps shutting it off.
Luckily I don't drive this truck every day because filling it often would probably drive me crazy.
72Kay20 Bel Air, MD
Other Toys
