Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-16-2012, 03:45 PM   #4
Portmod7
Portmod7's Avatar
Re: Torque wrenches and caliper bolts
Not doubting you, or your manual, and maybe I'm thinking of different caliper bolts than you, but 120ft-lb. seems WAY excessive. The caliper bolts are 7/16" if we're on the same page, and a 7/16" bolt (depending on grade and type) shouldn't ever be over 80ft-lbs. (60ft-lbs. lubricated) unless they are some special alloy (which I doubt). I would bet they are Grade 5 or so, and would torque to even less.
I just installed new Wilwood calipers on my truck, and I believe the instructions say 35ft-lbs. or so (I don't ever actually torque mine). The instructions also specifically stated to NOT lubricate the threads.
You should be able to pick them up on the Help rack at you local parts store, and I know CarQuest (others too I'm sure) usually stocks them boxed up in the back somewhere too.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
