Closed Thread
Old 08-14-2012, 10:51 PM   #4601
Bennett68C10
Bennett68C10's Avatar
Re: What did you do to your truck today!
Originally Posted by magwakeenercew2jh View Post
Whoa, Bennett! Very, very nice.
Thanks, I'm really happy with it. Sounds like you made some nice progress with yours.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 08-14-2012, 11:57 PM   #4602
Landlockt
Landlockt's Avatar
Ran it out of gas. I guess 10 mpg is overly optimistic.
_____________________________________
'71 GMC 2500 Custom Camper Sierra Grande
Landlockt is offline
Old 08-15-2012, 12:17 PM   #4603
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Too hot today in the Sierra Foothills. It's 84.4 F at 9:00...headed for another 110 F. So I went over to the shop and collected some paintable parts and headed back.
She winked at me as I went by.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-15-2012, 01:13 PM   #4604
DevilDog Aggie
DevilDog Aggie's Avatar
Installed my self-rebuilt carb and fired her up on the first crank!
DevilDog Aggie is offline
Old 08-15-2012, 08:08 PM   #4605
VDOG
Grand PooBaa Member
VDOG's Avatar
Wire wheeled the rusted out cylinder, just to see if its worth saving.
Just might rebuild the old gal
VDOG is offline
Old 08-15-2012, 09:29 PM   #4606
longbed67
longbed67's Avatar
Got the inside and outside in epoxy primer. BC/CC to come later this week
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 08-15-2012, 09:30 PM   #4607
asolde
asolde's Avatar
I had my engine out for freeze plugs then I cleaned it up. Test drove good today.
asolde is offline
Old 08-15-2012, 10:51 PM   #4608
UNEASYRIDER
UNEASYRIDER's Avatar
A little paint!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 08-16-2012, 03:18 PM   #4609
magwakeenercew2jh
It dropped to 96 degrees today. I spent a few hours on the money pit.
Put on the tailgate. Put on the hood hinges. Generally did a sort of stuff that goes, and the stuff that stays (I'm keeping a couple of dash set ups in case of a gauge failure or somebody needs to replace one.
Also, I'm keeping the clutch pedal and pivot and linkage. Never know if that close-ratio four speed is in the future....a few other things). Unfortunately, nobody around here wants stuff like four doors that
are about a 75-85 out of a hundred, some glass I replaced because is wasn't perfect, a bench seat that need a spring job, etc. So, I'll box up the tid-bit stuff that I think folks will be rummaging around for,
and the rest will go to the dogs.
Sorry about the dark interior shot. I forgot the flash.
I cleaned out the bed. It hasn't been this empty for three years. Since the start of the "build".
Getting close.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-16-2012, 03:57 PM   #4610
VDOG
Grand PooBaa Member
VDOG's Avatar
I added to the fun facts list by finding fiberglass and bondo.
VDOG is offline
Old 08-16-2012, 04:15 PM   #4611
bigdog57
bigdog57's Avatar
I put mine in the shop today to see if he can figure out why it won't startup. (it will turn over but not start)
Bigdog
bigdog57 is offline
Old 08-16-2012, 04:36 PM   #4612
RINC
RINC's Avatar
Yea for the drop in temps ! So I got me arse out to the garage last night.
Pulled my carb on the 72 to get rebuilt today. Changed out the bad headlights.
An tonight if the carb is done I'll throw it on.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 08-16-2012, 04:40 PM   #4613
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Drove it to the junkyard to source some old Mercedes engine parts , on the way home one brake drum began to squeak loudly , looks like a brake job is in the near future ~ it's prolly just a broken spring but I've been thinking of up grading the 2" drum brakes to the optional 2.5" ones.....
I don't want to tear it apart so close to Sunday tho' .
(got the Mercedes parts cheap !) .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-16-2012, 07:45 PM   #4614
VDOG
Grand PooBaa Member
VDOG's Avatar
If its a broken spring, then maybe just changing to new brake hardware may solve the problem.
VDOG is offline
Old 08-16-2012, 07:48 PM   #4615
VWNate1
VWNate1's Avatar
Prolly so ;
I have what else to do Fridy and Sat. AM , a broken brake pull spring isn't dangerous nor will it stop me from making this meet & greet .
-Nate
Geezer
VWNate1 is offline
Old 08-16-2012, 10:31 PM   #4616
critict1gc
critict1gc's Avatar
I wired up a relay for what I hope is the last bit to my tbi conversion.
critict1gc is offline
Old 08-16-2012, 10:59 PM   #4617
Hotrob72
Hotrob72's Avatar
1st I pulled out the old carpet
then I put in the new thanks to stockinterior
installed the new/old belts thanks to sharpie
had my seat recovered with a new vinyl cover
bought new stock wheel and Im just waiting to buy a tilt column...hope I find a good deal on a tilt
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 08-17-2012, 03:56 PM   #4618
69GWC
Gave it a bath..lol
69GWC is offline
Old 08-17-2012, 03:59 PM   #4619
cerjio
I drove it around ! then put my headlight bezels on finaly Been enjoyin just having it to drive after five long years of working on it !
cerjio is offline
Old 08-17-2012, 04:16 PM   #4620
magwakeenercew2jh
Got the hood ready to go on tomorrow.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-17-2012, 05:55 PM   #4621
elf w/capital T
what did you use??
elf w/capital T is offline
Old 08-17-2012, 05:56 PM   #4622
elf w/capital T
got door to close with no rubbage, mocked up driver side fender.
Old 08-17-2012, 06:59 PM   #4623
magwakeenercew2jh
Originally Posted by elf w/capital T View Post
what did you use??
It's almost the same thing as Dynamat. A little lighter and a lot cheaper. I bought it off of E-Slay.
I'll look tomorrow at the shop and see if there's a logo anywhere, but I think not. That's one of the reasons I bought it.
It was three years ago that I got it. And I can't even remember what I had for dinner last night.
It's hell getting old! Sorry.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-17-2012, 10:28 PM   #4624
Clanky
Clanky's Avatar
I replaced my cab mounts! I kinda stressed about this for a couple of weeks, not knowing what potential issues may arise, you know, stuff happening. I started at 7am and at 11:06am my '71 GMC K1500 was ready to hit the road, the project went really, really smooth. It was an awesome day in this man's driveway!
Clanky is offline
Old 08-17-2012, 10:37 PM   #4625
jc70chevy
jc70chevy's Avatar
went out side dumped fuel filter out and looked at all this cool black rtv looking stuff falling out filter... hhhhmmmm wonder why im stumbling under a load.. .. fml
jc70chevy is offline
Closed Thread
