Too Dumb To Know Better
Garage Floor Epoxy
Who has done it? Any tips? Prefered brand?
We are building a new shop and I want to do it before I get oil and grease all over it. Thanks, Doug |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: Garage Floor Epoxy
Decades ago, Varathane had a coating called Flecto Varathane...probably the grandfather
of todays better coatings. My uncle was a distributor and my dad used it in our basement. Tough as nails. As with todays better epoxies, "chips" were embedded in the finish. I know GACO makes a product for helipads. Definitely a professional product but, unfortunately, only available to licensed installers. I tried to get it for a customer a few years back and GACO refused to sell it to us. Professional grade coatings would be a worthwhile investment I would think (vs. home center brands). |
I sis my garage a couple of years ago with some product I got from Home Depot. I want to say Rustoleum. Was very simple to install.. You will just need to amke sure that the floor is somewhat clean and give it time to dry. After taht you just roll it on in sections and if you want throw some of the flakes on top (evenly. I am so glad that i did mine. cause I'm always ahving somekind of oil on the floor and this makes it a snap to clean up..
True |
![]() Join Date: Jul 2001
Ever have a problem with ''tearing out'' from hard cranking on a weighted tire from a moveable vehicle? Curious on this, would like to coat my shop floor. Is the ''Rustoleum" reasonably priced, shop is 35x50 (1750 sq. ft.)
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
72 GMC
Garage Floor Epoxy
Last week I did half the floor with Rustoleum Epoxy Shield. I bought it at Home Depot for about $60 a kit. No one ever mentioned that there are
different die lot numbers on the can lid. To get a consistant color, you need to mix all of the kits together before you do anything else, and then separate them back out to their original cans. I didnt do that so the first half of my garage has three different colors(three kits). Difference is slight, but I notice it. Other than that, I think it looks really good. It hasn't been "tested" yet, but I am told it holds up well. |
![]() Join Date: Mar 2011
I looked into this a while back and one thing I remember is that you do not want your concrete sealed (sprayed while concrete still wet) before using one of these coatings for maximum adhesion. You might want to ask your concrete guy about all this, I would imagine he would know any tricks about it.
Good luck on your project!
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
#7 | |
72 GMC
This is also covered in the rustoleum instructions. |
Thanks for the info. I will talk to the concrete guy about it. I've read that the concrete should be wet and it should be dry. So confused. I just know I want it.
68 C 10
![]() Join Date: Aug 2010
Go to the garage journal there is a whole section on flooring.
http://www.garagejournal.com/forum/f...splay.php?f=20
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
![]() Join Date: Jun 2006
Cement dries from the ground up, depending on the mix it will be dry faster or slower. I would have it shot with bed liner instead of an epoxy because you wont slip on the liner but you can on epoxy. You can get it any color you want.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#11 | |
I've been looking at doing this in my garage and the product I'm leaning toward is called "Armorgarage" Military/Industrial grade - 23 mils thick http://www.armorgarage.com/ulepco.html |
