![]() Join Date: Jan 2007
Re: C30 info
There are a couple of C30 campers being parted out in the for sale section with a 157" wheelbase frame (in Cali)....
I'm using the same frame in my K3500 conversion. However, here are my observations: The rear frame section, 8", kicks up higher than on a regular truck frame. Therefor, you will have to run an approx 3.5-4" body lift to match up with it. That will, in effect, also expose the frame. To combat that, I am mounting up side steps/bars to hide that. Also, I could be wrong, but the frame in front of the firewall seems to be of the SAME dimensions/modulus as all other trucks. I suspect if you're looking for a beefier frame to handle the torque you may still need to box that front end. Best of luck!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() Last edited by OldCreek; 08-17-2012 at 01:27 PM. |
