Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-11-2012, 12:18 PM   #426
70K10Hunter
70K10Hunter's Avatar
Re: Crash's 72 K10
I went to buy some supplies at my local paint supply store(primer,POR15,more sandpaper,etc. etc) and he recommended 3M brand All-around Autobody sealant #08500 it is in a caulking tube it is white. The guy says it's paintable, it wont harden like a rock but it will stay pliable somewhat? he said quite a bit harder than say RTV sealant.if thats any kind of reference? I will be getting my bed floor sandblasted probably next week then POR15 then assemble it. I'll try it and let you know how it goes.
70K10Hunter is offline   Reply With Quote
Old 08-11-2012, 10:52 PM   #427
67c10rustbuket
67c10rustbuket's Avatar
Re: Crash's 72 K10
Awesome inspiring work as always!
are you looking for the round clips that go on the rods to retain them to the levers on the heater controls?? I think a have a few 50 or so NOS ones I could donate a few to you.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-11-2012, 11:00 PM   #428
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Great.. I will pay you for them...
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 08-11-2012, 11:10 PM   #429
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Back at it this morning.. Flipped the bed floor over and cleaned the bed to prep it for the epoxy primer..
Sprayed the primer.. I reduced it more than I did on the cab.. Seemed to help a lot..
I worked out a lot of dents in the floor but stopped when I realized the pitting in the floor will reguire me to use a spray on bed liner to make it look right..
Then I fired up the sand blaster and started on the front of the bed and the rear inner fenders..
After that I started on the cowl piece.. Not sure what type of paint they had on this.. but the sand blaster had problems cutting it.. I will use the DA to finish it….
My goal now is to get rid of all of the yellow (original color).. I think all I have left is the bedsides and the tailgate…
Tomorrow I will start on working the dents out of the rear inner fenders…
Mark
Crash's 69 4x4 SWB
Old 08-11-2012, 11:15 PM   #430
67c10rustbuket
Re: Crash's 72 K10
These ?? Just tell me how many you need. PM me an address or ph number if you want to pick them up. No payment required for a fellow Okie. Looks like I was a little late or I could have gave you part of my old bed floor also. Mine has rot in the front and I just got another swb steel floor.
Dan <---(my name)
Old 08-12-2012, 01:37 AM   #431
quadzero
quadzero's Avatar
Re: Crash's 72 K10
I'm really enjoying this project, keep up the great work. The box is going to be fantastic.
quadzero is offline   Reply With Quote
Old 08-12-2012, 06:35 AM   #432
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Dan,
PM sent.. Thanks for helping me out on this. I figured someone would have the patch I was looking for as soon as I bought the new piece.. no problem, I have lot's of extra patch for others when they need it..
Once again thanks..
Mark
Crash's 69 4x4 SWB
Old 08-12-2012, 06:22 PM   #433
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks quadzero....
Mark
Crash's 69 4x4 SWB
Old 08-12-2012, 08:55 PM   #434
trashmanryan
Re: Crash's 72 K10
Crash, you making this look too easy, keep up the awesome work.
trashmanryan is offline   Reply With Quote
Old 08-13-2012, 08:10 PM   #435
driller35
driller35's Avatar
Re: Crash's 72 K10
Awesome job your doing on the build , shes going to look sweet when shes done
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD
70 Chev CST, 350 auto, PS, PB, AC, tach
driller35 is offline   Reply With Quote
Old 08-15-2012, 05:55 PM   #436
Gene
Gene's Avatar
Re: Crash's 72 K10
My bed had some pitting, I went with a color matched spray in bedliner. Looks great, thats the way you should go.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-15-2012, 05:58 PM   #437
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Gene,
Thanks... I hope the bed liner works for me.. Just finished reading your build, you truck is awesome... I can only hope mine turns out half as nice..
I am doing my build at Lake Eufaula.. Maybe I should shoot up HWY. 69 and check yours out some day...
Mark
Crash's 69 4x4 SWB
Old 08-15-2012, 06:00 PM   #438
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks driller....
Mark
Crash's 69 4x4 SWB
Old 08-15-2012, 06:00 PM   #439
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks for the positive comment.. Not sure about the easy part.. lol
Mark
Crash's 69 4x4 SWB
Old 08-16-2012, 06:18 PM   #440
Gene
Gene's Avatar
Re: Crash's 72 K10
Originally Posted by Crash_OK View Post
Gene,
Anytime, shoot me a PM.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-16-2012, 09:26 PM   #441
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Update from last Sunday..
Rebuilt the Fan Switch..
Started on the inside of the rear fender wells. The sand blaster could not cut the old factory weatherproofing. I used heat and a scrapper to cut the heavy stuff.. Then used some thinner to finish up.
This weekend I will finish sand blasting the tailgate, and bed sides.. then epoxy prime..
Mark
Crash's 69 4x4 SWB
Old 08-16-2012, 09:28 PM   #442
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Dan,
I received the clips in the mail today.. Thank you again for sending them.. They worked prefect… If I ever have something you need just let me know.. it yours..
Mark
Crash's 69 4x4 SWB
Old 08-16-2012, 09:47 PM   #443
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Worked on the AC control that MCBassin gave me, thanks again Mike, finished installing new control rods use the clips that 67C10rustbucket sent to me.. once again thanks Dan..
Looking for the screws that hold the cables on to the controller… Does anybody know what size and thread pitch they are?
Mark
Crash's 69 4x4 SWB
Old 08-17-2012, 01:40 PM   #444
67c10rustbuket
Re: Crash's 72 K10
Glad they worked out for you, I have plenty more gathering dust if you ever need more. Progress looks great. Might need to get myself a torch for the undercoat removal, looks like it worked well.
Dan <---(my name)
Old 08-17-2012, 01:45 PM   #445
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
It works well.. but it is slow.... after you get the thick stuff off.. then use somehting like thinner to cut the rest of it... once again thanks..
Mark
Crash's 69 4x4 SWB
Old 08-17-2012, 05:04 PM   #446
Gene
Gene's Avatar
Re: Crash's 72 K10
Is that the controls that come with vintage air? I love the factory look.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-17-2012, 06:09 PM   #447
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Gene,
This is an original AC Control I got from a fellow board member that I rebuilt. The vintage air piece comes with the AC kit from Vintage Air..
Mark
Crash's 69 4x4 SWB
Old 08-21-2012, 11:21 PM   #448
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 72 K10
Hey Crash, great looking build - very impressive range of skills and a ton of effort, it's going to be killer!
Zoomin is offline   Reply With Quote
Old 08-26-2012, 09:24 PM   #449
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Zoomin... Not sure about the skills.. but it has been a lot of effort..
Mark
Crash's 69 4x4 SWB
Old 08-26-2012, 09:38 PM   #450
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Crash's 72 K10
Very nice work!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
