Old 08-17-2012, 12:53 PM   #776
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Originally Posted by SCOTI View Post
That brake kit looks familiar .
Should be very similar to what you have. I went back and forth with the 'other' C5 brake vendor for a while, but kept coming back to Kore3 and Tobin for the quality and timeliness of response. So far very impressed with the quality of the parts and packaging as well. Hope this works...
Originally Posted by Bennett--G4L View Post
Nice Brakes
Thanks! Should pair nicely with rear discs- tired of pushing the brake pedal and hoping...
Originally Posted by tantrumpipeline View Post
A lot of fancy parts, look forward to seeing more updates
Thanks- me too! Coming soon- should have some mock-up pics in the next few days- gotta get them together and double-check wheel fitment
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-17-2012, 02:19 PM   #777
SCOTI
SCOTI's Avatar
Other than the black hub, I imagine they're the same. I did opt for the upgraded rotors vs standard C5 13" (I got the DBA 4000 13.4" Z51 spec'd solid rotors). Very nice package & Tobin was great to work with.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-17-2012, 03:07 PM   #778
gringoloco
A guy with a truck
gringoloco's Avatar
That's the cool thing about the Kore3 stuff- you can upgrade to ANY of the C5/C6 brake setups, including the monster Z06/GrandSport setups. I don't have the spoke clearance for the bigger rotors due to the way my wheels are shaped, so 13"-ish will have to do for now. Anything has gotta be better than the current push-and-pray.
My spindles are 1" rotor Belltechs, so these are actually the hubs spec'd for an Impala SS. They do offer hubs for both light-duty and heavy-duty truck spindles, but I don't see them listed on his webpage...
-Chris
Old 08-17-2012, 03:13 PM   #779
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Tobin is great to work with and hes right up the interstate from me...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-18-2012, 01:07 AM   #780
gringoloco
A guy with a truck
gringoloco's Avatar
The victim:
The carnage:
The mock-up:
It works ...at least on a stock spindle- don't wanna risk my 3" Belltechs until I know for sure they will work and fit. Next is test fitting a caliper and seeing if the wheel fits- the template was close!
-Chris
Old 08-18-2012, 07:47 AM   #781
67cheby
67cheby
67cheby's Avatar
Nice
67cheby is offline   Reply With Quote
Old 08-18-2012, 09:25 AM   #782
mcbassin
Still Learning
mcbassin's Avatar
I really like what you have going gringo. I may have to follow your lead on this when I ever get to that point. Keep the pics coming.
Old 08-18-2012, 09:41 AM   #783
SCOTI
SCOTI's Avatar
The drop spindles required less material to be removed when I did them.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2012, 12:23 PM   #784
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by 67cheby View Post
Nice
Thanks- gotta do something to try and keep up with you
Will do! I really wonder why more people haven't done this conversion- maybe it just needs a little advertisement. If this works out the way it's looking like it will, I may do a separate write-up. This can be done on the cheap, like ~$500 if you're willing to shop around know what you're looking for.
Good news! I think I'll have a machine shop do the drilling/tapping on the Belltechs- one, to make sure they're right, and two, my hands are killing me from tapping those 1/2-13 holes...
-Chris
Old 08-18-2012, 12:30 PM   #785
gringoloco
A guy with a truck
gringoloco's Avatar
...Keep the pics coming...
Ok! First, a couple of pics comparing the rotors, old vs new. Mmmmm... Beefy.
-Chris
Old 08-18-2012, 12:41 PM   #786
gringoloco
A guy with a truck
gringoloco's Avatar
Next, the caliper mock-up. Fits just like it belongs there. Weimaraner approved!
-Chris
Old 08-18-2012, 12:56 PM   #787
gringoloco
A guy with a truck
gringoloco's Avatar
...and wheel fitment. Due to the shallow hat on the rotor and the huge caliper, the caliper is extremely close to my wheel spokes. So close, in fact, that I'll have to install brake pads to determine if it's going to hit or not. With the caliper FULLY extended, it just barely grazes the back of the spoke- I'm hoping the pads are thin enough to allow some clearance, if not, I may need a small spacer. Coy's C5s apparently don't have this issue...
They do look good in there, though
-Chris
Old 08-18-2012, 01:03 PM   #788
gringoloco
A guy with a truck
gringoloco's Avatar
Old and busted vs new hotness:
-Chris
Old 08-18-2012, 01:11 PM   #789
raull
raull's Avatar
nicely done !!!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 08-18-2012, 06:04 PM   #790
Very Nice
Old 08-20-2012, 06:15 PM   #791
thor
thor's Avatar
Nice MIB quote. Oh yeah, nice brakes too.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 08-20-2012, 06:56 PM   #792
chevynova22602
chevynova22602's Avatar
Lol I'm ready to ruin mine now cause buy watching this thread you've ruined yours perfectly fine
chevynova22602 is offline   Reply With Quote
Old 08-20-2012, 10:01 PM   #793
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by raull View Post
nicely done !!!!!
Very Nice
Thanks guys!
Haha- wondered if anyone would catch that...
Thanks! Stay tuned- more to come. Now that I know the brakes work/fit there are parts-a-plenty rolling in on the big brown truck...
-Chris
Old 08-20-2012, 10:24 PM   #794
Bennett68C10
Bennett68C10's Avatar
Brakes look really good in the wheels, glad they worked out for you
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-21-2012, 03:16 AM   #795
wild4wheels
wild4wheels's Avatar
Fantastic build man.
Dave aka "Wild"
Current truck
"Ida Mae" 71 K5 Blazer
Former Trucks
"Loretta" 71 Longbed (AZ)
"Tanya" 69 Stepside (AZ)
"Ferdinand" 71 Longhorn (SD)
"Patches" 67 Panel (IA/ KY)
"Rosita" 68 C30 (KY)
Instagram @Wildforwheels @k5_klub @c10university
Profile pic provided by Jeff Sundance
wild4wheels is offline   Reply With Quote
Old 08-21-2012, 08:39 AM   #796
mcbassin
Still Learning
mcbassin's Avatar
Nice work! BTW, I could drill and tap your spindles if you get in a pinch. If you don't mind shipping them to me.
Old 08-21-2012, 01:46 PM   #797
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, me too! Drove her yesterday and realized again just how sub par the braking/handling is- cant wait to get this stuff installed
Thanks! I love these 'peaks' where there are new parts on the porch every day
Thanks a LOT for the offer- you do great work from what I've seen. Shipping would be killer, I'm sure. Still not yet sure if I'll do it myself...
-Chris
Old 08-22-2012, 03:04 PM   #798
Portmod7
Portmod7's Avatar
Awesome build! You knocked out a TON of work in a very short period of time, AND you didn't hack anything up, it all looks GREAT! Keep up the good work!
Congratulations on everything else too, you've had one heck of a year!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 08-22-2012, 04:34 PM   #799
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the positive comments- your truck looks outstanding, as well. Wish I could afford the TVS! As for this past year: man, you are NOT kidding! It has been a downpour of blessings and they just keep coming...
...so do the parts, for that matter--ordered Bilstein HD shocks all the way around today thanks to some help from Portmod Also, after seeing the plethora of negative commentary on the quality and general dissatisfaction with AGR steering boxes, I also picked-up a 'RedHead' quick-ratio steering box. I'd like to do the NoLimit R&P, but can't swallow the $800 price tag right now, plus I'd have to change engine mounts = not currently worth it. Maybe a future mod if the new box doesn't satisfy my needs.
-Chris
Old 08-22-2012, 08:11 PM   #800
gringoloco
A guy with a truck
gringoloco's Avatar
More parts arriving daily:
Porterbuilt (Addco) front anti-sway bar arrived today, required to compliment the forthcoming PB control arms. At 31lbs shipping weight and 1.25" diameter, it should be beefy enough to handle anything I can throw at it. It has all required hardware, including bushings that require NO GREASE
Requisite car parts in the living room shots:
-Chris
