Old 08-16-2012, 11:37 PM   #1
VWNate1
VWNate1's Avatar
Question Cowl Vents
Can some one please direct me to a detailed thread about these ? .
Mine are all rusted out and I'd like to see pix and ideas of what to expect when the fenders come off .
Do all '67 ~ '72' C/10's have left side cowl vents ? I see lots in the junkyard that do not appear to have them , I don't know if just covered up due to rust or what .
TIA , you alls are always very helpful to me .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 08-17-2012, 07:35 AM   #2
70cst
70cst's Avatar
Re: Cowl Vents
Here is a bump
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-17-2012, 08:33 AM   #3
camrycurt
camrycurt's Avatar
Re: Cowl Vents
Are you talking about the kick panel fresh air vents that feed air in from the cowl?
If yes, if you poke through the build threads on here you should find lots of pics of bare cabs that show what those look like once the fenders come off. Here's an example that shows some decent shots of the left and right vents: http://67-72chevytrucks.com/vboard/s...3&postcount=69
Hope that helps.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 08-17-2012, 09:21 AM   #4
Re: Cowl Vents
All trucks have both cowl vents...in the kick panels. A/C trucks use the passenger side one for air intake. The cowl takes the air...and water...in between the windshield and hood,then it passes down the front sides of the cab to where the vents are on the inside. Below the vents is the bottom of the air cavity where drain holes are...that get clogged by debris and often rust out. That area can be patched up,never to be seen again. I have enlarged the drain holes before,but the best thing is using screens behind the cowl panel to prevent the debris from ever getting in at all. Tri-Plus even makes that complete cowl panel if you want to repair it as built.
Old 08-17-2012, 11:44 AM   #5
54belair
54belair's Avatar
Re: Cowl Vents
If you are seeing rust now before the fenders come off---be prepared to take a deep breath.
I can only tell you for sure about my experience. The previous owner had hidden the interior rust with rtv and paint. We pulled the fenders to replace one rocker------
So far we have replaced the entire drivers corner of the firewall and a good part of the drivers side hinge post----as well as floors , rockers, and what ever else you can think of.
You will prob. find rust on the bottom of the air box and possibly part of the firewall. If you see it on one side, be sure to check the other as well.
Mine has turned into a rather expensive rust repair, but then Ive told my bodyman to call me with any surprises and let me make the decision----he has been very good to work with, but time is money and we will prob. end up with about 50 hours in the cab (at his shop) then there are things I will do to it when it comes home.
If you can see a little rust-----espect a lot more----and hope for the best.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 08-17-2012, 06:16 PM   #6
Lee H
Lee H's Avatar
Re: Cowl Vents
Nate, perhaps a picture of the area you are looking at? I'm still not sure what your asking about.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 08-18-2012, 12:35 AM   #7
VWNate1
VWNate1's Avatar
Post Re : Cowl Vents
Well ;
Therin lies the rub ~ I haven't yet taken it apart as it's my Work Truck see ? .
There are two cowl vents apparently , the left side one on my truck is gone & covered up with a kick panel .
The passenger side one was stuffed full of household fibreglas insulation , when I yanked it all out I not only found 5 pounds of leaf debris in there but the oval shaped thing that holds the vent flapper , was loose from the body , I can only imagine how bad the driver's side is if they covered it with upholstery .
I also have the rust holes on the horizontal part of the air intake on both sides (thanx GM for this particularly poor bit of crappy Engineering) so I've been considering a replacement cab even though my cab corners are rust free .
I'm a Mechanic , not a Body & Fender Man so I'm trying to figure out what to do , I spent much time looking for pictures in the old threads & didn't find a one , I'm not computer savvy although I can make junk run far better than you'd think .
So , a few pix or links to same would be highly appreciated .
-Nate
Geezer
Old 08-18-2012, 08:47 AM   #8
67c10rustbuket
67c10rustbuket's Avatar
Re: Cowl Vents
Here is my driver cowl fresh air vent. The outer skin has been cut away due to rust from soggy leaves etc sitting inside there. Does this help??
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-18-2012, 08:52 AM   #9
67c10rustbuket
Re: Cowl Vents
Their is a replacement for the entire outer cowl skin. If the rest of the cab is in good shape you may want to consider this. Drill out a bunch of spot welds, R&R, weld on the new..
Pic linked from GMC Pauls website.
Dan <---(my name)
Old 08-18-2012, 09:23 AM   #10
54belair
54belair's Avatar
Re: Cowl Vents
Unfortunately, the outer cowl skin is not always rusted--but the inner skin is.
If you are already considering an alternate cab--I would keep that in mind. You are right about the leaves, trash etc. and as it lays there it rusts the inside tray and the side air boxes. We all are overly aware of rockers and cab corners rusting but the average enthusiast isnt aware that the firewall is also a very costly area to work.
I had not one but two chances to buy a much better cab than what I had. Both times I elected to just repair the small damage mine had!!? All the while, the "small anount of damage" kept growing.
Now that we are nearing the end of the rust repair on the cab, I am satisfied that I have a good solid cab----but,, I could have bought one cab (that required very little work) for $800.-----My original cab.--when it gets to the point of being paint ready---will have cost
me more like $2400. Thats just repair costs!!
Im not whining --it was my fault for not knowing my project as well as I thought---but Im just saying----you might be able to Find one cheaper than repairing one.
Good luck with you project, youll enjoy it when its done---Im still looking forward to getting back on track with mine.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 08-18-2012, 12:04 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Cowl Vents
Here's a pic of what you DO NOT want to see....
Member Nr. 2770
Old 08-18-2012, 10:36 PM   #12
VWNate1
VWNate1's Avatar
Post Re : THANK YOU !! . ~ Cowl Vents
Yes , this is what I was hoping for .
Here in So. Cal. junkyards sell cabs for under $200 but , only a very few are any good .
Do these cabs have " hidden " VIN #'s like my '63 Nova did ? .
I have to be *very* careful here , the DMV & CHP are tough about cab swaps .
Any pictures showing the drain holes ? .
My outer cowl is fine , it's the inner portion where the leaves & debris accumulate that has holes in it .
67C/10RustBuket , your vents are in far better shape than mine are now .
Is it possible to carry a cab in the Step Side bed ? .
I have _zero_ body / welding skills and I'm too old & beat up to begin learning now so I have to take it to be fixed , I do plan to do this as I like this rig better than any of the hundreds of trucks I've had over the Decades .
I was born & raised Down East so I know all about how RUST NEVER SLEEPS .
-Nate
Geezer
Old 08-19-2012, 01:35 AM   #13
WIDESIDE72
WIDESIDE72's Avatar
Re: Re : THANK YOU !! . ~ Cowl Vents
Originally Posted by VWNate1 View Post
Is it possible to carry a cab in the Step Side ?
Its too big for a stepside.
A couple of years ago I sold a bare cab to a member on here (I forget his name but i think he was a cop. Nice guy, too) from the Houston area. I used my front end loader to lift it up and he backed his BRAND NEW shiny red chevy fleetside swb truck (09 or so)under it. He wanted me to drive the loader to his truck... Uh... My 67 Massey ferguson stops on a dollar, not a dime, and the cab was swinging everywhere!
WIDESIDE72 is offline   Reply With Quote
Old 08-19-2012, 02:03 AM   #14
VWNate1
VWNate1's Avatar
Post Re : Cab Transport
THANK YOU ! .
I thought maybe I could set the cowl's face into the bed....
I knew I'd get the right info here , you alls are the BEST ! .
-Nate
Geezer
Old 11-28-2016, 04:32 PM   #15
el_fantasma
el_fantasma's Avatar
Re: Cowl Vents
So I cleaned out the driver side easily. Lot's of leaves but no dampness, yea!
However, I have an AC cab and the passenger side looks like this.
Do I need to get in there too?
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 11-28-2016, 08:29 PM   #16
clay68c10
clay68c10's Avatar
Re: Cowl Vents
Yes, unhook the vacuum actuator and open the flap. It's always worth the time it takes to clean these out. There's always something in there.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-28-2016, 09:40 PM   #17
custom10nut
custom10nut's Avatar
Re: Cowl Vents
Once you're all done, make yourself some cowl vent screens (or buy them), and you'll never have that problem again.
custom10nut is offline   Reply With Quote
Old 11-28-2016, 10:17 PM   #18
GR8-68
GR8-68's Avatar
Re: Cowl Vents
I just started removing my cowl tonight, I am glad I did, I thought I got all those pesky pine needles out, Yea right I am going to get it removed make any repairs I need to, (luckily mine is minor if any) and then I will POR the piss out of it and weld on my new cowl. I will get pics for you
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 11-28-2016, 11:34 PM   #19
HO455
HO455's Avatar
Re: Cowl Vents
This is about the most complete pictorial of a cab I've run across. it is long but it seems like no area goes un-photographed.
http://67-72chevytrucks.com/vboard/s...d.php?t=705214
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 11-29-2016, 12:04 AM   #20
GR8-68
GR8-68's Avatar
Re: Cowl Vents
Excellent !! I was actually looking for that thread also I would say that is the furthest I have ever seen anyone go to save a cab
Larry
"Project 68"
paypal.me/ldgrant
Old 11-29-2016, 12:57 AM   #21
el_fantasma
Re: Cowl Vents
You just unhook the rubber hose and pull open the flap, is it that easy? I ask because I tend to break stuff.
Old 11-29-2016, 01:40 PM   #22
weq92f
weq92f's Avatar
Re: Cowl Vents
Here's mine all buttoned up...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is online now   Reply With Quote
Old 11-29-2016, 06:27 PM   #23
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Cowl Vents
Money very well spent. I did the same.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-29-2016, 06:48 PM   #24
clay68c10
clay68c10's Avatar
Re: Cowl Vents
Yes, pop the vacuum line off and open er up. You can take the linkage off too if it seems like you need a better look in there. It's been years since I had an a/c cab truck, so I don't recall how visible it is with the vacuum pod hooked up, or if it restricts the movement of the flap too much.
13 Tahoe LTZ
