Old 08-18-2012, 11:01 PM   #1
78f1hundo
250 engine ?
I need a motor for my 65 C-10 and a buddy on mine has a nice one out of a 67 Chevelle that does not blow smoke and runs real good.
Is there any differences between the two? I know that brackets and the exhaust may not line up. But is there a major difference or is this a major no-no.
Or should I just hold out for a 250 out of a truck?
Thanks,
Steve
78f1hundo is offline   Reply With Quote
Old 08-18-2012, 11:21 PM   #2
CRGRS 66
CRGRS 66's Avatar
Re: 250 engine ?
You will get some good advice, and in short order I suspect. I can't say for sure, but I can't imagine you would have any issues with this swap.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 08-19-2012, 04:54 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 250 engine ?
Mounts should be similar as well as the exhaust. No major differences between the Car/Truck motors unless you get a later smogger head. Comparing the two you'll see the difference right away.
Old 08-19-2012, 11:14 AM   #4
geezer#99
geezer#99's Avatar
Re: 250 engine ?
Have a look at the oil pan sump. Some had the sump in the front on the cars. Truck is in the rear.
geezer#99 is online now   Reply With Quote
Old 08-19-2012, 11:21 AM   #5
corvettejim1968
corvettejim1968's Avatar
Re: 250 engine ?
if you do ending on holding out the 3 engine options for the 65 were the.
230 strait six
292 strait six
283 V-8
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 08-19-2012, 04:22 PM   #6
Wrenchbender Ret
Re: 250 engine ?
It should fit perfect & work fine. Some later ones had a 3 bolt flange were the ex. pipe hooks to. If so you can put the 3 bolt flange on your pipe.
Wrenchbender Ret is offline   Reply With Quote
