Closed Thread
Old 08-17-2012, 02:21 AM   #5951
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: What did you do to your truck today?
It was way too hot today to do much work, and I lost power at the shop almost right after I got there. So all I did was pull my downpipe back off the truck so i can take it into the exhaust shop tomorrow morning and have it shortened a couple inches. All assembled it hung WAY too close to the ground for my taste, it should be good to go by tomorrow afternoon.
fryer1979 is offline
Old 08-18-2012, 02:34 PM   #5952
corvettejim1968
corvettejim1968's Avatar
installed these speakers in the dash. pain in the butt took 3 hours. it sounds much better so its worth it.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline
Old 08-18-2012, 05:05 PM   #5953
CRGRS 66
CRGRS 66's Avatar
Drove it to Guelph (20 min drive) to deliver a piece of furniture to my brother (lovely morning to be cruising with the tunes blasting), then brother and I went off to Mississauga (45 min drive) to an alcohol store to get some supplies for next weekend, check out the bounty 52 Ales, and lagers from home and abroad (shame we can't get any US craft brews up here, love the brew pubs you guys have down there). Got home, and fixed my gas gauge, when it did work it was flopping all over the place, I thought it was the gas sloshing around. I originally thought it was a grounding issue, turned out to be the power wire was loose. Reads real good and steady now. Then I took her to the car wash, and powered washed a lot of guck and grime off of the front suspension. It will soon be time to tear down, and add 2.5" drop, and power disc brakes!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 08-18-2012, 05:33 PM   #5954
Indian113
Indian113's Avatar
Drove it to Altoona,had to pick up some lumber to work on my house.
Thumbs up's and nice truck-may dad had one JUST like it. Ya gotta love em
Indian113 is offline
Old 08-18-2012, 06:02 PM   #5955
towersddg9
towersddg9's Avatar
Decided to go with Dakota Digital
towersddg9 is offline
Old 08-18-2012, 08:20 PM   #5956
contagious102
contagious102's Avatar
Picked a front cross member with new ball joints,2 1/2" drop spindles,and 1 1/4 disc brakes ,with 5 on 5 rotors for 300 bucks.!! My 66 step will enjoy the up grade.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline
Old 08-18-2012, 09:01 PM   #5957
RollinKaos
RollinKaos's Avatar
Tried to tow it to my new house and a rear tire blew. Truck bounced around on the trailer and crushed the rocker panel, side and rear of the bed. Door is a little bent but fixable. After a few hours in the desert sun getting back on the trailer and off at the new house, I am in no mood to get the tires fixed and really access the damage.
Betty :
'63 Fleetside Longbed
350 w/ 4 speed
CPP 3/5 drop with front sway bar.
RollinKaos is offline
Old 08-18-2012, 11:17 PM   #5958
CRGRS 66
CRGRS 66's Avatar
Even though I plan to get started on tearing into some fairly major work in about a months time, I decided to clean up the deluxe wheel I picked up recently, and put it on. Man it is big!!! Makes it quite a bit easier to maneuver in parking lots, and... I like it
Craigerrr
CRGRS 66 is offline
Old 08-18-2012, 11:19 PM   #5959
CRGRS 66
CRGRS 66's Avatar
Tomorrow will be a better day, at least no one was injured.
Craigerrr
CRGRS 66 is offline
Old 08-18-2012, 11:26 PM   #5960
scotts62
One day...
scotts62's Avatar
Installed engine and trans
Scott
93 crew cab build
Project 62
scotts62 is offline
Old 08-19-2012, 12:05 AM   #5961
exoticmetalworx
exoticmetalworx's Avatar
i got it on the road last week took it to the first car show today
exoticmetalworx is offline
Old 08-19-2012, 06:41 AM   #5962
a37lesalle
a37lesalle's Avatar
Loaded it with some stuff to move to new house. First time I took it for a drive longer than a block. Did find some issues while driving the old girl. But it made it all the way on her own.....with a little bit of a load.
a37lesalle is offline
Old 08-19-2012, 08:19 AM   #5963
glos55
glos55's Avatar
Ordered 1" lowering blocks and adjustable tracking bar for rear
glos55 is offline
Old 08-19-2012, 03:08 PM   #5964
62 Barnfind
62 Barnfind's Avatar
Completed the grill.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 08-19-2012, 03:39 PM   #5965
JPBrecheisen
Rebuilding and reconditioning the closed knuckle 44 on my 62 K1000. There is obvious damage on the balls, but I got some metal epoxy to spread into the grooves, then I'll fair it down with some emory paper onces its fully cured.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline
Old 08-19-2012, 03:50 PM   #5966
jjzepplin
jjzepplin's Avatar
Bought her a new frame converted to 2wd.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 08-19-2012, 03:58 PM   #5967
rendus
rendus's Avatar
Took mine on a 60 mile drive yesterday and discovered two things:
1. the throttle spring was too weak and began to stretch causing my throttle to stick
2. a little oil is dripping out my stock oil breather. Not alot, just enough to leave drops and streaks on the valve cover and inner fender.
Today I installed a beefier spring on the throttle linkage (found it in the garage, it's about the size of the clutch return spring, so no worries with it stretching)
My 250 has the stock valve cover and a twist in hole for the oil breather. I had the proform oil breather pictured below but it is push-in. I cut the twist in base from the stock breather and welded it to the base of the proform breather. Fits like it's made for it. I figure the proform is taller and the filter material is a tight enough weave to slow down the oil spray.
'66 C10 250 3-on-the-tree
'68 Galaxie 460/C6
'74 914 2.0
rendus is offline
Old 08-19-2012, 04:03 PM   #5968
steve'62
steve'62's Avatar
62 barnfind, grill looks awesome, I had a 62 so I can appreciate its rarity! It's a love it or hate it relationship for most people on here with the 62 grill!
steve'62 is offline
Old 08-19-2012, 05:42 PM   #5969
wagonslayer
Started painting the roof, roll on rustoleum satin white and some silver metal flake for fun.(haven't added the metal flake yet)
wagonslayer is offline
Old 08-19-2012, 08:56 PM   #5970
LT1 Burb
LT1 Burb's Avatar
Started bolting parts back on the frame.
LT1 Burb is offline
Old 08-19-2012, 09:28 PM   #5971
66clow
66clow's Avatar
Too hot for you with a avatar like that!!
66clow is offline
Old 08-19-2012, 09:31 PM   #5972
198plus
198plus's Avatar
Let me know how you like it, I think I'm going to go with it also
198plus is offline
Old 08-19-2012, 11:00 PM   #5973
towersddg9
towersddg9's Avatar
Thumbs up, its only bout an inch thick fits the bezel much better than the billet piece I had in there, excellent quality you will need to use the oil and temp sending units that are supplied in the kit (tip top on those as well), plus comes with programmable speedo that will replace the cable, I'm not sure on the bezel color yet, been looking for a chrome version but can't find it, I need to stop changing things so I can start driving it, I'll post some better pics in a few days
Old 08-19-2012, 11:55 PM   #5974
64thunder
made a rice burner ashamed of his puny 4banger noise with my american six pack
then went around the appt complex giving kids rides in the bed
64thunder is offline
Old 08-20-2012, 09:57 AM   #5975
jsdoyle
jsdoyle's Avatar
That would look awesome in my truck! Let me know if you don't like it!
jsdoyle is offline
Closed Thread
