Old 08-20-2012, 12:34 AM   #1
mexlokote
mexlokote's Avatar
help me find.......
ok i have an 1982 chevy custom deluxe with original straight six engine i am looking to find a valve cover also air cleaner must be chromed, also some spark plugs that would fit my engine and im trying to find them on ebay...
any help? please
also would like to know if it uses a 2bl carb or 1bl?
links would really help!!!
im new to this so please be patient thanks,
mexlokote is offline   Reply With Quote
Old 08-20-2012, 12:41 AM   #2
wwj75c30
wwj75c30's Avatar
Re: help me find.......
lmc has chrome does have chrome valve covers and if i renember air cleaners too no links tho sorry
wwj75c30 is offline   Reply With Quote
Old 08-20-2012, 04:44 AM   #3
grs
You can get the spark plugs at an auto parts store.
grs is offline   Reply With Quote
Old 08-20-2012, 06:32 AM   #4
D13
D13's Avatar
Assuming it has the origianl motor, it wil be an integral head with a 2-bbl carb. Take the toop of the air cleaner, if you see one round hole it's the Monojet, if you see 2 slightly squarish holes it's the 2 bbl. A little bick finicky to work on but decent carbs.
You will find NO chrome parts unless you have them chromed. You wil find NO hop up parts (other than cam stuff) unless you replace the head with an earlier version, in which case none of your brackets will work and your carb won't fit.
Spark plugs, any auto parts store, do not run Champion. Bosch and NGK are good but pricey.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
