Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-05-2012, 08:28 AM   #701
Iron-Butt
454 club
Iron-Butt's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
I need one. The website to order is not working.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 07-05-2012, 10:38 AM   #702
Pro Performance
Pro Performance's Avatar
There is an orange button at the bottom of where you enter your information. Just hit that, and everything should work and allow your credit card info to be entered.
Please give me a call @ 480-420-8175.
Thanks,
Travis
Pro Performance is offline   Reply With Quote
Old 07-19-2012, 12:34 PM   #703
chevy72blu
chevy72blu's Avatar
Got mine in a few days ago from the July 4th special. Its beautiful!
I have never messed with fuel pluming though and I have a question.
Does anyone have a diagram of which bungs are to be used for what? Obviously the low outlet is going to be used for the flow, and I know one of the top bungs will be for return (EFI), but what about the other (center, near the pump wiring posts)?
chevy72blu is offline   Reply With Quote
Old 07-19-2012, 02:43 PM   #704
Daveboyd
Daveboyd's Avatar
if you purchased an EFI Tank. The center 3/8 NPT fitting on the EFI housing is your Fuel out. The bottom fitting is just a drain and the 3/8 on the same side but furthest from the cap is your return.
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 08-21-2012, 12:35 PM   #705
Daveboyd
Daveboyd's Avatar
just a quick update:
for the last few months we have been back and forth with how to improve this product. Below is a list of a few changes that have been made that i believe helps the overall quality of this tank.
1) First thing we did was changed the way we formed the bottom of the tank. instead of using 90 degree punch we changed to a 1" radius. this will give the tank a much smoother finished look when installed. This will be on all 67-72 tanks. Pics Below (it was hard to capture in a picture)
2) We improved our EFI Pump Bracket Mainly just for fabrication purposes. not much of a noticable difference in the end product.
3) We improved our Gaskets for the EFI.
4) We improved our packaging and inspection processes.
5) The biggest change we made on this product is we are now building to inventory instead of building to order. This has drastically decreased the lead time on these tanks from 7-10 business days to 2 business days or less. Powdercoated tanks will still be 7-10 business days. There are still bugs in making this happen but we have been working very hard to reach these goals.
These few improvements have all been done and did not effect the overall price of the tank.
Dave Boyd
Old 08-21-2012, 01:24 PM   #706
DUTCHMAN
DUTCHMAN's Avatar
Just ordered mine last friday, hope I get the improved version.
06 BMW 330d aut touring full option
83 Jeep CJ7 360 aut sold
71 GMC Suburban
67 Chevrolet C10 stepside
54 Ford F100 sold
49 Chevrolet coe
48 Ford f6 coe
Strijen
the Netherlands
"NO MISTAKES NO PROGRESS"
DUTCHMAN is offline   Reply With Quote
Old 08-21-2012, 02:05 PM   #707
LDO
LDO's Avatar
When can we expect the next group buy??
LDO is offline   Reply With Quote
Old 08-21-2012, 11:26 PM   #708
idreama300
Has anyone tried to mount the tank to the underside of the top frame rail to gain ground clearance? What kind of a charge (if any) would there be to move the mounting brackets lower to allow the tank to sit up higher?
idreama300 is offline   Reply With Quote
Old 08-21-2012, 11:40 PM   #709
Portmod7
Portmod7's Avatar
I mounted mine to the bottom of the frame as intended, and once I got my bed on (stepside with wood) there was only about an inch of clearance between the top of the filler neck and the floor of the bed. So the only thing i think would help in moving it up is to put some kind of flush fitting cap in the top of the tank.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 08-22-2012, 11:31 PM   #710
idreama300
Sorry I failed to mention that I'll be raising my bed floor.
Old 08-24-2012, 01:39 PM   #711
Portmod7
Portmod7's Avatar
You'd be ok then, except that the rear crossmember will be in the way. That one is pretty easy to relocate though, I be you could move it far enough back, or maybe use a Porterbuilt style instead.
Old 09-06-2012, 09:45 PM   #712
scott72
scott72's Avatar
I also think the mounting flanges could be moved back on the tank a little, the front edge of them actually do not contact the frame because it starts to curve upwards over the axle. Mine is moved back slightly, so it pretty much cured that issue, but if I wouldn't have moved my rear crossmember there would have been about 1" or so of the mounting flange on the tank that didn't even contact the frame.
Doesn't look like too many people have this mounted on a lwb, but looking at this same thing.
I am guessing I should keep it flush with the frame, instead of pushing it back towards the crossmember, which would make the flanges stick out like you say.
I bought a porterbuilt rear crossmember, so want to make sure I have room for it as well.
scott72 is offline   Reply With Quote
Old 09-09-2012, 10:26 PM   #713
RPIcka
do the stock gauge sending units work on these tanks?
RPIcka is offline   Reply With Quote
Old 09-10-2012, 01:42 AM   #714
yukon
What size are the supply and return lines for the efi tanks?
yukon is offline   Reply With Quote
Old 09-12-2012, 08:37 AM   #715
Portmod7
Portmod7's Avatar
I don't know much about senders, but what comes with the tank is supposed to work with the stock gauge. It's set up for a sender that bolts in with 5 bolts, so I don't think a stock sender will work.
3/8" NPT
Old 09-26-2012, 12:20 AM   #716
68 TLC-10
can we get a group purchase for the tank? I'm in need for one soon.
68 TLC-10 is offline   Reply With Quote
Old 09-28-2012, 01:47 AM   #717
jonny..2008
wish i could figure out how to get one of these.
to fit in my budget i mean.
i love every machine. even the ones i hate.
Current project (1959) fifty niner gmc fleetside:
http://67-72chevytrucks.com/vboard/s...70#post6514670
MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460
jonny..2008 is offline   Reply With Quote
Old 09-29-2012, 07:16 AM   #718
budder71
I haven't read all of your threads and if you have addressed this I am sorry for the
repetitive questions.. but ... what is the larger/largest tank that you offer for a 68 Chevrolet
Suburban 4WD and does it look/fit as if it looks stock...?? and also is the pricing still approximately $10.00 per gallon ??? thanks
budder71 is offline   Reply With Quote
Old 09-29-2012, 01:51 PM   #719
eagleuh1
eagleuh1's Avatar
Nice improvements on an already nice product. How about can you put a bigger vent in it. Mines spurts or burps gas up when filling from above bed 2 inch fill line. Think its trapped air burping it out some. Gonna try and put small tube down through fill to vent out. Thanks. Jim
eagleuh1 is offline   Reply With Quote
Old 10-21-2012, 03:19 PM   #720
nlped
nlped's Avatar
It is getting towards the end of the year...When is the next group buy ?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-26-2012, 02:53 AM   #721
THE DRIVER
I'm in for a group buy also, has anyone with a 3/4 ton lmb requested a longer tank for more capacity? wood bed leaf spring non EFI bed fill btw.
THE DRIVER is offline   Reply With Quote
Old 11-17-2012, 12:56 PM   #722
capt68
capt68's Avatar
How does the group buy work? I need one and a friend of mine is wanting one as well. I've got a few questions for the specs on the tank when it comes time to order, like tank fill locations, etc.
Russell
Russell
capt68 is offline   Reply With Quote
Old 11-17-2012, 11:40 PM   #723
eagleuh1
eagleuh1's Avatar
Can't fit a longer or wider tank in without removing a crossmemer, which braces the frame at your spring perches. You could fit a deeper or taller tank, but that would be a custom order anyways. There is a few inches to go up to the bed floor brace, but they would have to move the rollover vent, it sits right under a floor brace. If you got measurements, they could probably build you one that would fill in between between floor braces, but it would have to be custom. Good luck. Mine is a long bed, leaf spring C20 by the way.
Old 11-21-2012, 01:41 PM   #724
Daveboyd
Daveboyd's Avatar
Travis @ Pro performance and I have teamed up for the last time this year to offer an excellent sale on All Carb & EFI fuel tanks. Here is a link to his thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=552685
This sale is only authorized exclusively for azproperformance.com you will not be able to get this through any other dealer or our website so now is the time.
Everyone have a Great Thanksgiving!
-Dave
Dave Boyd
Old 11-24-2012, 01:01 PM   #725
rophle
Got mine ordered today. Thanks for the sale.
Ronnie
rophle is offline   Reply With Quote
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
