Old 08-27-2012, 09:37 PM   #1
csdineley
csdineley's Avatar
Headers ??
Hello
I have a 87 R20 350 tbi and my stock manifolds are being a pita. So I was thinking about getting some headers. And after searching and reading for hours now. I'd thought I'd just ask. Long tube, mid length, or shorty's? Would there be any real difference in a stock 350 tbi as a daily driver?
csdineley is offline   Reply With Quote
Old 08-27-2012, 09:54 PM   #2
mopar346
Re: Headers ??
For convenience of running pipes and in my opinion a better look and performance, long tubes. I have been running Hedman Elites for the last few set due to 3/8 flange, the ball type collector, quality and accurate fit. They do cost a little more but the fit better than any I have ever installed. I use the ceramic ones and I have been very pleased.
mopar346 is offline   Reply With Quote
Old 08-27-2012, 10:12 PM   #3
3r!c84
Badass
3r!c84's Avatar
Re: Headers ??
if you plan on lowering your truck more than 5 inchs up front you want to rethink long tubes. but besides that they are great. also dont cheap out and get painted ones they will burn off that paint and rust so fast. get ceramic coated ones. or jet-hot coated like i have.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-27-2012, 10:31 PM   #4
csdineley
csdineley's Avatar
Re: Headers ??
No lowering planed, and I was thinking about stainless. I guess my main concerns are fitting them and O2 sensor. The mid's I found have the o2 sensor bung, but the long tubes don't.
Old 08-28-2012, 01:02 AM   #5
psycobilly77
Re: Headers ??
Long tubes will give you better sound and low end torque. As for the O2s, you can get the weld in bungs for next to nothin.
1977 Scottsdale shortbed stepside 4x4.
350, 4spd, NP205.
10 bolt front, 12 bolt rear
4"(?) lift and 35s.
psycobilly77 is offline   Reply With Quote
Old 08-28-2012, 02:07 AM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Headers ??
If you spend the money on long tube Doug's or Doug thorley they don't hang lower than the frame. Then you have nice ceramic covered headers that don't rub
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-28-2012, 07:16 AM   #7
mopar346
Re: Headers ??
You can get collectors with the O2 bung in them for about $25 from Summt if needed.
I've never run Doug's but they have been around for 40 years so they must have something going for them.
Old 08-28-2012, 01:34 PM   #8
INSIDIOUS '86
Re: Headers ??
They will also weld in bungs for you or anything custom
Old 08-28-2012, 02:35 PM   #9
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Headers ??
If you move the O2 sensor that far back (to the bungs) make sure to switch to a preheated sensor and save yourself some headaches.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-28-2012, 05:20 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Headers ??
Chevelle headers!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-28-2012, 07:32 PM   #11
csdineley
csdineley's Avatar
Re: Headers ??
The mid's I found look just like those Chevelle one's. So they fit well?
Old 08-28-2012, 08:58 PM   #12
story
story's Avatar
Re: Headers ??
I just bought and installed some headers from O'rielly's for my 87' R10, since they never seem to have anything that fits a R10 but had some for a 86 C10 in stock I took those... Cheap ones $150 I also have a TBI 350 and there is a O2 on the drivers side... No place had a bung so we cut one of a stock Harley pipe and welded it in the drivers side header... The air pump tubing or whatever that was running from the exhaust behind the motor was a PITA to remove but other then that it was easy.
Stock Harley pipes
Done...
story is offline   Reply With Quote
Old 08-28-2012, 09:06 PM   #13
story
story's Avatar
Re: Headers ??
Opps forgot something I have power steering and AC... Had to cut a piece off the bracket at the front bolt by the number 1 cyl. Hope this helps.
Old 08-28-2012, 10:39 PM   #14
54Caddy
GM Addicted
54Caddy's Avatar
Re: Headers ??
How low is your truck?? Measurment from fender to level ground would help. Looking for headers but dont have much clearance with a 26.5 tall tire and 5 inch drop in the front. Dont really like the chevelle headers due to plug wire routing was a PITA on the chevelle i just got done building.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 08-28-2012, 11:56 PM   #15
csdineley
csdineley's Avatar
Re: Headers ??
Stock ride height for 3/4 ton 2wd and 30" tires. No plans to lower it, so I don't think ground clearance is going to be a problem. But thanks plug wire routing is something to consider.
Old 08-29-2012, 02:07 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Headers ??
Caddy dougs d310c. Mine tuck nice.
http://m.summitracing.com/parts/dou-d310
KQQL IT is online now   Reply With Quote
Old 08-29-2012, 03:01 AM   #17
54Caddy
GM Addicted
54Caddy's Avatar
Re: Headers ??
Got some pictures KQQL IT??
..Mac’s Garage..
IG:MacsGarage
Old 08-29-2012, 11:02 AM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Headers ??
Old 08-29-2012, 02:00 PM   #19
INSIDIOUS '86
Re: Headers ??
I'm on a 6-8 drop. Still saving for Doug's long tubes with O/2 bungs but they are still out of my budget. All I know is Doug's sit about 4in higher next the frame and you need a double humP crossmember
Old 08-29-2012, 02:26 PM   #20
54Caddy
GM Addicted
54Caddy's Avatar
Re: Headers ??
Nice, might have to snag up a pair of these headers very soon
..Mac’s Garage..
IG:MacsGarage
Old 08-29-2012, 02:55 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Headers ??
I started with a double hump...
Old 08-29-2012, 03:39 PM   #22
gchemist
gchemist's Avatar
Re: Headers ??
You bet they fit!!
This is the lowest the headers hang!!
Old 08-29-2012, 04:05 PM   #23
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Re: Headers ??
Long Tube!!! I have shorties and they are always loosing the bolts!!!
Smoke_Dog is offline   Reply With Quote
