08-17-2012, 12:35 AM | #1 |
Lower belt molding ?
I done a mock up with the molding pieces I had. I am trying to find the rest. It seems tough to find reasonable priced lower belt molding. I like the way it looks..whatchaw thank?
Mr.Magoo |
08-17-2012, 08:41 AM | #2 |
Re: Lower belt molding ?
Looks great. How & where did you decide to place the molding, relative to the body line?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-17-2012, 12:14 PM | #3 |
I just lined it up with the ridge of the body. I just used sticky pads to put it on so I could see if I liked it. Now I just gotta find the other 7 more pieces.
08-17-2012, 01:57 PM | #4 |
Looks great!
I'm adding trim to a non-trim truck as well - what clips are you going to use to mount the trim, the original ones that require holes or the adhesive plastic clips? I was originally going to use the metal clips, but now I'm not sure about drilling all the holes and am thinking about just using the adhesive clips and am interested in your thoughts. Thanks.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
08-17-2012, 02:01 PM | #5 | |
08-17-2012, 11:20 PM | #6 |
I want to use adhesive strips too...I need some feedback on the same subject. I dont wanna drill no holes..
08-17-2012, 11:56 PM | #7 |
I drilled the holes in my yellow 69. took me a couple of hours, mostly measuring.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
08-18-2012, 12:37 AM | #8 |
If I got to drill holes I might as well use small screws evenly spaced and paint over the head.
08-18-2012, 06:07 PM | #9 |
I dont think I want to drill 300 holes in the body of my truck. That seems kind of silly with the quality of adhesive tape available these days. With proper prep, 3M tape will NEVER come loose.
08-18-2012, 06:22 PM | #10 |
Never thought about 3m tape to hold the molding on, I was wanting to put some on my 69 but did not like the idea of drilling holes but some tape is sure alot more painless..lol
08-18-2012, 08:04 PM | #11 | |
I drilled mine because a friends molding was coming off after about 6 months with quality 3m tape. He has owned a body shop for 20+ years and actually was the one who advised me to drill holes and use the factory style clips.
08-18-2012, 08:10 PM | #12 |
Moderator
I would use the factory clips. They mount behind the moulding and you cannot see them. If you use screws, you will see them (even if you paint the heads) and it will look horrible. While 3M tape holds up pretty well, it pushes the moulding out away from the body. Using factory clips will snug it up flush and it will look like it should.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-18-2012, 08:15 PM | #13 | |
X-2 Posted via Mobile Device
08-21-2012, 02:31 PM | #14 |
I don't know what pieces you need but here's some misc lower molding being sold on the parts board now: http://67-72chevytrucks.com/vboard/s...d.php?t=539250
08-21-2012, 11:09 PM | #15 | |
08-28-2012, 11:28 PM | #16 |
I got my molding set in yesterday and I started stripping and cleaning them today getting them ready for painting. I got a nice 12 piece set w mounting hardware from my new good buddy Cash3481.
08-28-2012, 11:54 PM | #17 |
subscribed
