Old 08-27-2012, 08:30 PM   #1
Joe69C10
Joe69C10's Avatar
69 C-10 disc brake conversion help!
Hey guys, I'm doing front disc conversion and need a little help. I bought the stainless line kit from CPP. Also bought booster / mast cyl / & prop. valve from Pirate jack.
My main question: The stock front drum set up had 1 line running to the proportioning valve, that split into two and fed the front drums.
The new set up I bought has two small holes, and one large. (Im guessing each front now needs its own line? Or can I plug one of the holes and run the new front disc set up off 1 line off the prop. valve?
Pics below of where I am now. The lines look like puzzle pieces that done fit. (awesome) lol
Joe69C10 is offline   Reply With Quote
Old 08-27-2012, 08:37 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 69 C-10 disc brake conversion help!
Plug the top hole on the front.
That's what I did with mine.
You will need a "inverted flare" plug.
Keith
Convert to disc brakes.
Old 08-28-2012, 03:08 PM   #3
Joe69C10
Joe69C10's Avatar
Thanks Keith!
Old 08-28-2012, 07:05 PM   #4
Xeen
Xeen's Avatar
If you are talking about the T connector for the front brakes down by the crossmember, then you should be using all 3 sides, once for each caliper and one for the prop valve. The line comming from the back of the prop valve goes to the rear brakes and has a straight through connector.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-28-2012, 08:53 PM   #5
lolife99
lolife99's Avatar
He's talking about the extra front port on the aftermarket prop valve.
Keith
Old 08-28-2012, 10:03 PM   #6
RichardJ
Joe 69 C10, you said you got your MC from Pirate Jack. I got this first image from their web page. If this is the same MC, you are connecting your lines up backwards.
lolife99, your MC looks to be the same one and yours is backwards as well.
The rear of the Pirate MC has the larger reservoir and must be connected to the front disc brake calipers.
Drum brake MC does not need a large reservoir, because the shoes are adjusted as they wear either by the owner/mechanic or the brakes are self adjusting.
Disc brake calipers do not have any means of adjustment. With that small reservioir feeding two calipers, the MC will run out of fluid and start pumping air when the pads are worn about half way.
When that combination valve is mounted under the radiator on the crossmember, it also serves as the distribution block for left/right front brakes. I don't know what year they moved it down there.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 08-29-2012, 12:44 AM   #7
lolife99
lolife99's Avatar
My m/c has two equal size reservoirs.
(you can tell by looking at the lid)
Just like the old corvette master cylinders.
It's an aftermarket set up from PerformanceOnline.
It's designed to work with their disc/drum prop valve.
Works great on my '69.
The prop valve you posted is indeed different.
It's a 73-87 frame mounted version (in front of the engine) unlike the 67-72 style that hangs under the M/C.
Keith
Old 08-29-2012, 02:27 AM   #8
Xeen
Xeen's Avatar
Ah he didnt do an arrow or circle it in the picture so I was wondering what he was talking about I didnt notice there was an extra port on the prop valve.
