Old 05-31-2012, 06:17 PM   #1
JRBECK64
Door Locks on my 67
Have you ever seen a door that will lock with the key when its open but when you close it, it wont lock with the key??? I never seen anything like this and im hoping its just a adjustment issue... If anyone has run into this please let me know what you did to fix it... Thanks
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 05-31-2012, 06:35 PM   #2
john
member #16
john's Avatar
Re: Door Locks on my 67
That is usually caused by wear in the latch pawl. Try pushing in on the door while locking. You can also try backing the adj. off a bit.
john is offline   Reply With Quote
Old 05-31-2012, 08:08 PM   #3
JRBECK64
I tried to back the Striker out some with no help to the problem. So this is probably not going to be fixed short of putting in a new latch assembly... I really didnt want to have to pull my inner door panel back out... Oh well thats the cost of not replacing it when the door was completely torn apart...
JRBECK64
I will have to put that in my lessons learned book...
Old 05-31-2012, 08:38 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Roll your window down and spray some penetrating oil (not WD40) on the latch and locking mechanism. You can see it with a flashlight if you look down inside the door at the back of the glass. Spray the crap out of it... Like John said, 90% of the time it's because your door isn't closing all the way. Move the striker out a little more and make sure the latch isn't dragging on it..
LockDoc
Leon
Old 06-01-2012, 06:38 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Two of my trucks do this on the driver side so I'd say wear too. I have to push in on the door when locking them. Passenger sides both work perfectly.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-01-2012, 06:47 AM   #6
JRBECK64
LockDoc
LockDoc,
I did almost exactly what you described in your post yesterday with no fix. In fact I sprayed so much PB Blaster in there the door is seeping!!! So Im guessing that the latch mech is just worn out. I brought the door out enough with the striker that there was an 1/8 inch gap on the back side of the door and if it needs that much I would rather go through the pain of pulling the door panel. That door has been a real pain as far as shutting since I hung it and put in the Door Seals. I replaced the Driver side Latch and it shuts really nice but as I remember now everyone in the local area was out of the Passenger Side Door Latch so that is why I didnt replace it. Patients is another thing I need to learn on these projects.
JRBECK64
Old 08-26-2012, 01:37 PM   #7
OC 72
OC 72's Avatar
I have a similar issue...passenger door does not unlock unless you push down on the lock knob....when the door opens..then the key does not come out...any ideas on issue?
OC 72 is offline   Reply With Quote
Old 08-26-2012, 02:57 PM   #8
LockDoc
LockDoc's Avatar
Tough call on that one without seeing it. Pushing down on the button should lock it. I would say you either have the wrong lock pawl on the cylinder (there is a right and left) or it is not installed correctly. The key will only come out in the vertical position. If you haven't seen this thread read it...
http://67-72chevytrucks.com/vboard/s...d.php?t=425488
Any other questions post 'em up.
LockDoc
Leon
Old 08-26-2012, 02:59 PM   #9
OC 72
OC 72's Avatar
Thanks Doc! I
Old 08-26-2012, 03:03 PM   #10
LockDoc
LockDoc's Avatar
Originally Posted by OC 72 View Post
Thanks Doc! I
I added to my post above so you may want to read it again.
LockDoc
Leon
Old 08-29-2012, 09:51 AM   #11
OC 72
OC 72's Avatar
Took a picture of the lock...
I'm assuming that the lock sprowl needs to be vertical over the "c" latch..correct?
Old 08-29-2012, 02:11 PM   #12
LockDoc
LockDoc's Avatar
The lock pawl is not in the correct position. It needs to be in between the two legs on the door latch, and it is bent down. The angle should be 90º.
Look at the pictures again in the link I posted... The lock pawls aren't exactly the same but that doesn't make any difference.
LockDoc
Leon
