Old 10-10-2003, 12:01 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
Question diameter of rear U-bolts
Anyone know what the rear u-bolt diameter is for a 71 2WD? Probably no different than the diameter on any other trailing arm chevy truck. Gonna have a new pair of U-bolts made and this is the number one question I keep getting asked.
sactoC10 is offline   Reply With Quote
Old 10-10-2003, 12:36 PM   #2
Custom 68
Custom 68's Avatar
I just drilled some holes in a plate for my u-bolts and used a 3/4 inch bit. The size was close so depending on the stock they have it is slightly less than 3/4 inch. Hope this helps
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-10-2003, 12:55 PM   #3
sactoC10
71 DELUX
sactoC10's Avatar
Yeah, when I am talking to these places (the parts stores more than the BIG RIG fabricators) I keep getting asked, "Are they 5/8 or 9/16 inches?" And they are definitely thicker than "normal" so that "close to 3/4" size sounds right.
I can't get a quote over the phone unless I know the right size and I'd rather not run all over town for quotes with my U-bolt in hand. There are several places in town that will make them "while U wait" but the local Napa store is much closer, so I am trying to find out so I can buy a pair from them.
Thanks!
Old 10-10-2003, 02:28 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
The napa store won't have them. They have to be manufactured. I bought mine this summer, went into a local truck spring shop, laid the bolt on the counter.
The old guy said: 1/2 ton Chevy pickup.
Yes
67-72.
Yes.
Let me go get them.
They were already made, in stock, cost about $15 each. 3/4", I can't recall the width and length. Measure them and find out.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-10-2003, 03:02 PM   #5
jef5150
Inline 69
jef5150's Avatar
go to a 4x4 shop that installs lift kits, http://www.suspensionconnection.com/...tion/to=x.html
jef5150 is offline   Reply With Quote
