Question about later model wheels
I have a 1966 GMC 3/4 ton. Still has drum brakes all around. I need to get some new wheels. does anyone know if the new style wheels will fit our trucks? Something like this:
New-2011-13-Chevy-Silverado-GMC-Sierra-2500-3500-HD-8-Lug-20-Wheels-Rims-Tires Or like this: 16-8-Lug-OEM-Duramax-Wheels-Chevy-Silverado-2500HD-GM-Rims-4x4-HD-GMC-Diesel-LT I'm not buying off of ebay, but just threw those up as examples. Any info you have will be appreciated. Thanks. Rob |
![]() Join Date: Aug 2004
Re: Question about later model wheels
you need to check the rear wheel opening around the axle shaft area. the front should fit fine but the back would be in question.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#3 | |
![]() Join Date: May 2007
the first ad pretty clearly says it will only fit the 11-13 models because the pattern has changed. maybe they edited that after you posted the link but my gut says no. I have seen pictures of the second type on trucks on this forum. that one may be a possibility depending on the center bore size like clyde said.
Yes, I have found that the 8 lug pattern was changed in 2011. No longer 6.5.
Posted via Mobile Device |
Who Me?
I would watch your backspacing too. Some of the modern wheels model look fairly flush on the outside and may not fit well. I think old rims like ours need a more centered hub.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
