Old 08-30-2012, 12:39 AM   #11
Edahall
Re: Need some help towing a 77 K25 on a towbar
I've done a lot of towing using tow bars and the biggest issue is stopping / slowing down. So keep your speed down and leave plenty of room ahead.
Your tires will easily handle the K25 in a turn. But do air them up to the maximum allowable pressure for stability.
Also, make sure your tow bar is fairly level when hooked up.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
